Installing Timer Switch, No Ground Wire In Switch Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2009, 05:23 PM   #1
Installing timer switch, no ground wire in switch box
I am attempting to replace a regular switch with a timer switch. The problem is I don't see ground wires (green/copper) coming from the switch box. How do I attach the green wire from the timer switch to the actual switch box?
diydan is offline   Reply With Quote
Old 05-25-2009, 07:43 PM   #2
If the box is metal, you don't need to. The switch will be grounded via the screws (assuming the box is grounded).
If you feel the need to ground it, there will be a 10/32 tapped hole in the back of the (metal) box for a ground screw.
If the box is plastic you will need to add a pigtail to the existing ground wires.
If there are no ground wires, you are probably not going to have a ground available anyway. Move on.
220/221 is offline   Reply With Quote
Old 05-25-2009, 07:51 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
duplicate
Note: Agree with 220/221
Disclaimer
& Stay Safe
.....Bob Lavery
ground ? in old two wire elect system wis_remod Electrical 14 02-24-2009 11:07 AM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
