Installing Timer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 01:23 PM   #1
Rewards Points: 26
Installing timer switch
Hey guys,
I am placing a timer switch at my office. Taking off the current regular light switch this is what I see:
1 copper wire(left side) - which I am not sure how best to connect to the correct wire on the timer switch(cap or clamp)
2 black wires(right side)
The timer switch has:
1) blue - load
2)black - line
3)white - neutral
Please inform me which wire goes to which. Thank you in advance.
peequi is offline   Reply With Quote
Old 11-24-2011, 02:16 PM   #2
Sparky
Rewards Points: 510
with the switch off one of the black wires will still be hot, this is your line. the other black is your load wire.
the white neutral wire goes with the white wires tucked in the back of the box. unless there is a green screw somewhere on the new timer it doesnt need a ground connection, you can tuck the bare copper in the box.
use appropriately sized wire nuts to make your connections/
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
peequi (12-10-2015)
Old 11-24-2011, 02:46 PM   #3
biggles's Avatar
with the switch in the OFF position you need to go with a meter SW Black to copper then the other SW Black to copper see which has 115V in the off positon got it.remove that black and wire nut it to the timer black.now that the timer BLUE and screw it onto the switch where the SW black came from.then the timer white to a neutral wire hopefully it is in the wall box the switch came out of? forget the raw copper just tuck it into the back of the box....reinstalling switch.if you don't have a white neutral for the timer white...got to do what you have to do.remember your not breaking the neutral with the switch but the hot feed to the LOAD(light)
The Following User Says Thank You to biggles For This Useful Post:
peequi (12-10-2015)
Old 11-24-2011, 05:13 PM   #4
joed's Avatar
Rewards Points: 13,340
You can't install that timer. It requires a neutral connection. There is no neutral in your switch box. You have a switch loop.
The white wire connected to the switch is being used as a hot wire.
The bare wire is a ground. It connect to the green screw or green wire of your new switch.
Old 11-24-2011, 05:34 PM   #5
biggles's Avatar
if you want to install the timer up in the light that's where your WHITE neutral is for the timer WHITE..if you had a spare wire coming down from the light in the SWITCH area you would just bring the Neutral down into the switch box....
Old 11-24-2011, 05:59 PM   #6
Sparky
Rewards Points: 510
i want to know why you think there is no neutral wire in the switch box guys, there is no white wire connected to the switch, there are 2 BLACK. they look to me like they've been painted a bit 2 wirenuts tucked in the back of the box in picture #2, i assumed one was the grounds and one was the neutral..
Old 11-24-2011, 06:04 PM   #7
Rewards Points: 582
agree with you techy there should be wires tucked in back neutrals...2 black on switch leg and not black and white....
Old 11-24-2011, 07:08 PM   #8
joed's Avatar
After closer examination you are correct. The wire in the second picture definitely appears to be white.
The bare wire goes to the green screw or green wire if there is one on the switch.
You will need a meter to determine which black wire is the hot wire. That is the one which goes to the timer black.
The other black goes to the blue load wire.
The white switch wire goes with the other whites in the back of the box.
Old 11-24-2011, 07:33 PM   #9
biggles's Avatar
poster take a pix of that yellow wire nut pulled out so we can see its color...if it is white check each switch wires to it and see if you get 115 bounce...then your good to go
Old 11-25-2011, 08:13 AM   #10
Rewards Points: 26
Sorry guys. Yes there are 2 wires that are tied together buried in there. I should have taken a photo of that as well.
Thanks!
Old 11-25-2011, 10:50 AM   #11
biggles's Avatar
if you hit the hot on that switch and to them thats your neutral if you go from the wire nutted pair to raw copper and get 115V its hots wire nutted
Old 11-25-2011, 03:45 PM   #12
Rewards Points: 26
Thanks. That makes sense that one of the black wires will still be hot, not sure why I didn't realize that in the first place!
Thanks for pointing out those white wires, I didn't notice them at first.
Incase someone runs into this thread do exactly what Techy said:
white to 2 white wires
line to hot wire
load to non-hot wire
This unit that I purchased does not have a ground(it is a modern Honeywell product)! I am 100% sure there is no ground. Very strange but it is working fine.
Installing Switch In Reversing AC Motor RetiredLE Electrical 18 10-26-2014 10:51 PM
Timer switch at end of run tmaher Electrical 3 05-16-2011 06:06 AM
Trying to install wall timer in place of switch bigcutts Electrical 3 02-02-2011 03:41 AM
GE Smart Timer in a 3 way switch vanisle Electrical 8 10-27-2010 12:34 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
