Installing A TED 5000 - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2011, 11:59 AM   #1
Rewards Points: 6,652
Installing a TED 5000
Any opinions on using the two 20 amps for the whole house surge on our Square D QO panel, to connect the MTU to, for power of that unit? I figured that instead of putting in two more breakers just for the mtu, and that since the QO breakers can be double-tapped.
I figured that the whole house breakers, would give the less noise on the mtu, since all they do, is sit there to look pretty, to power up the whole house surge. I figured that I would plug the gateway into the outlet that is on the side of the load center, and that for the ethernet cable, my network rack is right there, so I will not have to pull a new cat-5e run.
Old 10-04-2011, 12:06 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Greg.,
If you are talking about the whole house surge surpessor yeah I have done that few time { as long the manufacter say it ok to tied to one of the two pole branch circuits } then it is not a issue I have done few the same thing with intermatic whole house surge supressor with two pole breaker.
However let me give you a head up with extreal surge supressor jamais { never } cut the conductors shorter.
Merci.
Marc
Old 10-04-2011, 12:14 PM   #3
I have the Intermatic whole house on my panel. I figured either hook the wires there, or put on the dryer or a/c. Figured the noise from those two, would be too much for the mtu. I like the Power house dynamics eMonitor, but $945 for a 24 slot panel is way more than I would want, just to be able to monitor the house in general.
Old 10-04-2011, 12:43 PM   #4
Just hook up any spot but not with motour load too much noise as you say and that is true and also when they start up they can wreck hovac on them some case.
945 USD ?? for Dynamics eMonitor that is pretty steep price Merde !
Merci,
Marc
Old 10-04-2011, 01:03 PM   #5
I thought that also, but if I had my father in-laws place, I would spend that to track use, since he has two outbuildings and the main house. Our place is about 821 sq ft, and only thing that runs all of the time, since I am home until dec. all the time, is the plasma.
Looking at the info on the Ted, it is a learning curve, but will be a neat toy, to go along with the wifi thermostat that I have. I figured since I am changing from the radiothermostat.com app, to ourhomespaces.com, I figured step it up to make the home a little smarter. What I have tried to look for yesterday, is something that I can use to track gas use more effectively, instead of waiting for the bill to just show up once a month.
Installing foam board around windows ? Arky217 Windows and Doors 3 09-12-2011 04:13 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
Method for installing 3/8" engineered hardwood poolecw Flooring 10 10-31-2008 03:10 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
