Installing Switch And Tamper Resistant GFCI Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 09:50 PM   #1
Rewards Points: 12
Installing Switch and Tamper Resistant GFCI Outlet
Ok so I am trying to make a switch in my bathroom into a combo switch and plug .
I have uninstalled the switch to the only light in the bathroom and currently have the combo switch wired - the wrong way unfortunately - trying to fish through the internet failed me - now I am here.
See diagram below...
In the switch box there is a line coming up (I am assuming from the breaker box) with a white and black wire. There is also a line coming down (I am assuming from the light currently in the bathroom) with a black, white, and red wire.
On the combo switch I purchased there are two brass screw on one side and two silver screws on the other - along with two black copper wires coming out of the combo switch itself.
Any ideas on how I can install this the easiest way? I know you can have it so the plug works all of the time and the switch turns the light on and off - which is what I would prefer, however if the easiest way is to make it so plug goes on and off with the switch that is fine.
Thanks in advance
Installing Switch and Tamper Resistant GFCI Outlet-bathroom-diagram.jpg   Installing Switch and Tamper Resistant GFCI Outlet-pic-broom-2.jpg
jasonbran16 is offline   Reply With Quote
Old 09-03-2013, 09:51 PM   #2
Rewards Points: 12
One more thing there is no connecting tab on the side between either set of screws...
Old 09-06-2013, 02:55 PM   #3
Not A Licensed Pro
Removed my response until you read the back of the device and let us know what the writing to each terminal and wire says... or a diagram inside the box it came in.
You mention NO ground wires coming in, so without a ground, you cannot properly wire a 3 prong receptacle... much less wire this up as a GFCI protected circuit!
kevinb70 is offline   Reply With Quote
Old 09-06-2013, 03:14 PM   #4
Not A Licensed Pro
Old 09-09-2013, 12:31 AM   #5
Rewards Points: 12
got it
thanks but i already figured it all out
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 11:14 PM
3 Way Switch Issue (after replacement) mpukit Electrical 11 09-20-2010 04:12 PM
