-   -   Installing Switch and Tamper Resistant GFCI Outlet (http://www.diychatroom.com/f18/installing-switch-tamper-resistant-gfci-outlet-186443/)
jasonbran16 09-03-2013 09:50 PM
3 Attachment(s)
Ok so I am trying to make a switch in my bathroom into a combo switch and plug .
I have uninstalled the switch to the only light in the bathroom and currently have the combo switch wired - the wrong way unfortunately - trying to fish through the internet failed me - now I am here.
See diagram below...
In the switch box there is a line coming up (I am assuming from the breaker box) with a white and black wire. There is also a line coming down (I am assuming from the light currently in the bathroom) with a black, white, and red wire.
On the combo switch I purchased there are two brass screw on one side and two silver screws on the other - along with two black copper wires coming out of the combo switch itself.
Any ideas on how I can install this the easiest way? I know you can have it so the plug works all of the time and the switch turns the light on and off - which is what I would prefer, however if the easiest way is to make it so plug goes on and off with the switch that is fine.
Thanks in advance:)
jasonbran16 09-03-2013 09:51 PM
One more thing there is no connecting tab on the side between either set of screws...
kevinb70 09-06-2013 02:55 PM
Removed my response until you read the back of the device and let us know what the writing to each terminal and wire says... or a diagram inside the box it came in.
You mention NO ground wires coming in, so without a ground, you cannot properly wire a 3 prong receptacle... much less wire this up as a GFCI protected circuit!
kevinb70 09-06-2013 03:14 PM
jasonbran16 09-09-2013 12:31 AM
got it
thanks but i already figured it all out
