Installing Switch In Side Of Cabinet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 08:14 AM   #1
installing switch in side of cabinet
I'd like to add another light switch in my bathroom, near the doorway. There is a narrow area between the door frame and a wall cabinet, but there are studs behind this area, so no room for an electrical box. Below the cabinet is a granite backsplash, which I don't want to cut through. I'm thinking of putting the switch into the side of the cabinet. Would this violate any codes? The box would be inside the cabinet, but I'd put wood around it so that it's not visible or touchable. Any problem doing it this way? Thanks for any help.
sm99 is offline   Reply With Quote
Old 06-03-2009, 08:21 AM   #2
DIYer
A box in the cabinet should be fine. You need to protect the romex going into the box somehow if people will be jamming stuff in the cabinet. A piece of Liquidtight flexible metal conduit or EMT would work, or you can just put wood around the wire as well.
The box doesn't really need wood covering it on the inside.
BTW- if you use metal conduit, use a metal box and don't forget to ground the box.
Gigs is offline   Reply With Quote
Installing a ceiling fan with a light switch. Unregistered Electrical 9 08-23-2011 03:36 AM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 05:04 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
