Installing Switch From Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 01:54 PM   #1
Angry
installing switch from outlet
Trying to install 2 outlets and an on off switch in an outside building. I have everything wired, when I put power on, my on off switch doesn't work. There is a light plugged into each outlet. The on off switch is on the off position, but yet the lights come on when I put main power on. When I turn the switch to "on", I blow a fuse. What am I doing wrong?
purplepirate is offline   Reply With Quote
Old 08-25-2010, 01:56 PM   #2
Licensed electrician
Rewards Points: 996
It would help greatly if you could describe the wiring sequence you used.
Old 08-25-2010, 02:02 PM   #3
Sorry, I really don't know much about this. At the main outlet, there are 4 screws (two on either side), I have white on bottom screw and black on brass screw on opposite side (diagonal from each other). From there I piggybacked to next outlet and connected wires the same on that outlet. From there I piggyback to an off off switch. There are 3 screws (2 silver on top and one brass on bottom). I attached black wire to brass screw on bottom and white wire to silver screw on top opposite side (wires are diagonal from each other). The on/off switch is in the off position. When I power on at fuse box, the fluorescent lights I have plugged into the outlets come on. When I turn the on/off switch to the on position, the lights turn off, but fuse blows.
Old 08-25-2010, 02:10 PM   #4
Rewards Points: 156
So, you're trying to turn the lights on and off with the switch?
what you've got right now is a switch wired as a "short circuit" at the end of your circuit. As soon as you flip the switch to "ON" you're providing a short circuit and the breaker trips. (as it should)
You've got to place the switch between the first outlet and the breaker. Switch only "hot" wire (black in this case) and never the "neutral" wire. (white in this case)
moondawg is offline   Reply With Quote
Old 08-25-2010, 02:47 PM   #5
Rewards Points: 996
Sounds like you want the switch to control both receptacles. If so you need to take the power to the switch box first and then run to the receptacles.
Old 08-25-2010, 03:27 PM   #6
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
Power coming in (black) -> switch screw 1
Power coming from switch screw 2 (black) -> outlet 1
connect neutral (white) wire to outlet 1.
Piggyback outlet 2 from outlet 1 (white and black).
Also, ground properly for your setup.
hyunelan2 is offline   Reply With Quote
Old 08-25-2010, 04:45 PM   #7
I am so confused now. Yes I am trying to control lights at the outlets with this switch. I've gone out and bought a one switch/one receptacle combination to put at "the beginning" where I have one light. When I wired it according to the diagram included, it did turn on/off the light with the switch. But it doesn't do the same with the other light at the other outlet.
Old 08-25-2010, 05:28 PM   #8
Resolved
Got it figured out...Everything works fine now...ty.
Installing dedicated outlet for generator only iabteri Electrical 21 12-13-2013 03:46 PM
Switch outlet in bathroom odale Electrical 7 12-11-2009 08:04 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Half outlet / Half switch tb582 Electrical 3 10-01-2009 09:55 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
