Installing Switch From Hose To Attached Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 06:54 AM   #1
Rewards Points: 113
Installing switch from hose to attached garage
I want to put switch in house to control lights in garage. How do i run romex from garage through drywall into house? Do i need to use conduit to secure wire. Thanks
EFTHIM is offline   Reply With Quote
Old 04-29-2012, 08:06 AM   #2
joed's Avatar
Rewards Points: 12,902
Without seeing your house the general principal is to cut holes in the drywall and drill holes through top plate to fish the cable. Or if you have an open attic above you might be able work from the attic and avoid some of the holes.
Then patch the holes when finished.
Water/Sewage Draine Line Addition to Attached Garage CZ DIY Plumbing 9 01-30-2012 08:26 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Questions regarding wiring 220 to attached garage... John Green Electrical 0 01-20-2011 09:23 AM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 12:25 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
