Installing Sub Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-01-2012, 05:51 AM   #16
macon, ga bibb county
Rewards Points: 150
Bump bump
Lupus71 is offline   Reply With Quote
Old 12-02-2012, 06:16 AM   #17
Rewards Points: 150
Ok I've decided to go with a 60 amp sub in the shed but now I've been reading where people say #6 thhn is not rated at 60 amps because you have to go by a certain degree rating in celcius and its only 55amps that way. So can I use #6 for a 60 amp panel? Also the sub panel powering my house is already grounded on different bars right?
Old 12-03-2012, 05:25 PM   #18
Rewards Points: 150
Now im second guessing a 60amp breaker. I did a load calc and came up with 38 that's two tools running, lights, and an ac unit. So with that said I have also decided to look into aluminum and I am confused on the type. It will be in PVC conduit I think #4 will work but do I need urd, ser, or this stuff called underground secondary distribution cable? Also can I put #4 in a 100 amp or if aval. A 75 amp breaker and still be under code and have a 100 amp sub?
distribution panel amperage rating tom31415926 Electrical 10 08-26-2012 04:09 PM
Need some help installing a 60A sub panel stradt03 Electrical 22 02-09-2012 05:37 PM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
Critique my Sub Panel rjniles Electrical 18 05-17-2011 11:31 PM
Installing panel blac1175 Electrical 6 05-02-2011 12:27 AM
