Installing Spotlights? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2008, 06:56 PM   #1
Installing spotlights?
Hi there I am looking to install spotlights in a kitchen. the switching and single light are there so I can extend the cabling to each spotlights. the plastering of the ceiling is getting done after I go and I was wondering what you think would be the best way to tackle installing these spotlights either to feed the cables across using a snake and taking notches outof ceiling when a joist is in the way or take floorboards off above?
eddyg2007 is offline   Reply With Quote
Old 03-22-2008, 07:04 PM   #2
When is fishing season?
CowboyAndy's Avatar
You can't hold off on the plaster until the lights are in? that way you could just unscrew the sheetrock and be good...
I have pulled up floorboards before to run lights, and it all depends on the situation. I had to pull up 110 year old 1" hemlock boards, and alot of them started to split and had to be replaced. But, the room I was pulling up floor boards was already gutted so I had easy access.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-22-2008, 07:08 PM   #3
what you mean?
yeah i prefer floorboards unless its wooden flooring your stuck
Old 03-22-2008, 07:56 PM   #4
YID
I would snake and drill through the joists (not notch). Then you can screw that piece of drywall back in that you cut out.
Way faster.... usually.... though I'm never the "drywaller" too, when I do it
YID is offline   Reply With Quote
Old 03-23-2008, 09:56 AM   #5
How can you drill the joists if they are not possible to get to with the drill??
Old 03-23-2008, 10:48 AM   #6
CowboyAndy's Avatar
There are long flexible drill bits (4 ft i think). I have never used one, but i assume that you would cut a hole in the rock, stick in the flexible bit and drill as far as you can, then cut another hole, etc. I have seen alot of the guys here mention using them, so I'm sure they will chime in.
MY HOUSE OWNS ME!
Old 03-23-2008, 10:34 PM   #7
I'd cut and patch the plaster around the joists.
220/221 is offline   Reply With Quote
Old 03-24-2008, 12:50 PM   #8
yeah that seems like the better idea
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
Installing T&G birch ceiling NeedHelp Building & Construction 6 12-29-2007 09:09 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
