Installing Recessed Lights On 2nd Fl Bed Room - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 03:28 PM   #1
installing recessed lights on 2nd fl bed room
My question is what is the best way to get power to a new wall switch to controll a new set of can lights. There is no attic access. There curently is a switch at the disired location which controlls a receptical in this bedroom that doesn't have ceiling lights. Or is there a way to use the exsisting receptical switch?
thanks much
Zipster
zipster is offline   Reply With Quote
Old 03-05-2012, 03:53 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Fish tape usually does the job. Sometimes two fish tapes are needed.
What is the wall made of? Sheetrock?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-05-2012, 03:59 PM   #3
Get ready to cut! You need to drill through the top plate so you'll have to cut a decent sized hole in the top of the wall. Then you should be able to cut a rework box into the wall and fish between that hole, the hole at the top and the hole for the pot light.
fdiddy is offline   Reply With Quote
Old 03-05-2012, 04:07 PM   #4
Licensed electrician
Rewards Points: 1,864
Depending on the wiring of the switch you may be able to use the existing switch and pull power from there. Then all you would need to do is drop a cable into the switch box and go to the first recessed.
Old 03-05-2012, 04:09 PM   #5
rrolleston's Avatar
Metal coat hangers work too for grabbing the fish tape when you feed it from the hole for the light to the wall. Just get it close to the hole hook it and pull it down. Next time I have to do this I should make a how to with pictures or video.
Watch out for that blown in attic insulation that stuff is messy.
Old 03-05-2012, 04:36 PM   #6
would that be if the existing switch is middle of run and if so will the switch still controll the receptical and the pots?
Old 03-05-2012, 04:39 PM   #7
Sparky
Rewards Points: 510
if the power goes to the switch then recep you can drop the cans to the switch, and keep the receptacle switched or make it 100% hot.
if the power goes to the recep first,and loops to the switch, you can drop the cans to the switch and make the recep 100% hot
Techy is offline   Reply With Quote
Old 03-05-2012, 06:41 PM   #8
Rewards Points: 978
this is kind of my question too. how do you know which way the power is going and coming?
federer is offline   Reply With Quote
Old 03-05-2012, 06:48 PM   #9
You just need to know what you are looking at.
Old 03-05-2012, 06:52 PM   #10
rrolleston's Avatar
With the power off post pictures of inside the boxes so we can see try to help.
Old 03-05-2012, 07:45 PM   #11
If line goes to receptacle first, there might not be a neutral at the switch and he wouldn't be able to feed the lights.
Old 03-05-2012, 07:51 PM   #12
But it is possible to re-configure a switch loop to provide a neutral to the switch.
Commercial Electric vs. Halo recessed lights bubbler Electrical 0 10-12-2011 07:06 PM
Fitting Recessed Lights wedge22 Electrical 7 08-12-2011 12:24 PM
Wiring Basement Recessed Lights RyanNirg Electrical 1 10-14-2010 05:40 PM
help installing wall and recessed lights. nancyT Electrical 4 09-15-2010 01:58 AM
Recessed lights fifaboy Electrical 2 02-22-2005 07:41 PM
