Installing Recessed Lighting Trim - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 08:16 PM   #1
installing recessed lighting trim
I have a Juno IC10-R can in my bathroom, and bought a gimbal trim (http://www.junolightinggroup.com/product_detail.asp?ino=2090&Sel_Id=1624&br and=1) to go with it. I have figured out how the bulb fits to the trim, and obtained a whip adapter so the bulb can move with the gimbal.
My problem is that the trim has two spring loaded rods on either side. It seems obvious that you squeeze the two sides of the rods together and insert them somewhere so that the spring action holds the trim in place. BUT... I can't figure out where you would insert them! Any ideas?
lwb1 is offline   Reply With Quote
Old 09-01-2010, 08:43 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Very easy just look at two " C " clips on the can walls that where you put the springs on them and slide them up and ya are done.
Merci.
Marc
installing trim and moldings faintchimes Remodeling 5 04-08-2017 10:46 PM
Recessed Lighting - Which Fixture? allen1466 Electrical 2 12-29-2009 09:42 AM
Other Options For Recessed Lighting Bulbs jte1130 Electrical 1 11-07-2009 10:57 AM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
recessed lighting automation cesar333 Electrical 3 12-28-2005 08:54 AM
