Installing Recessed Lighting In A New Drop Ceiling - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 03:38 PM   #1
Installing recessed lighting in a new drop ceiling
Is there any trick to make it easier to install recessed lights in a drop ceiling? Should I wire the light up first, then install the tile (with the hole cut, and then mount the light fixture? I don't know how I would get the tile in with the fixture already in place.
Thanks,
rwood@weg.net is offline   Reply With Quote
Old 11-30-2011, 03:54 PM   #2
Rewards Points: 115
cut out the tile first. install that tile. remove one or two other tiles to access the top of tile you cut out. you can drop the fixture in the cutout from above and do all your wiring from above also. be sure to support the fixtures with chain or wire to framing members. do not let them be supported by ceiling grid only. good luck
pokey is offline   Reply With Quote
Old 11-30-2011, 03:54 PM   #3
Licensed electrician
Rewards Points: 1,054
It is easier to cut the tile then install the recessed. Add the surrounding tiles after you have secured the attachment legs to the grid.
Wireless Light Switches (for installing recessed lighting) htabbas Electrical 1 10-30-2011 07:44 AM
installing recessed lighting trim lwb1 Electrical 1 09-01-2010 09:43 PM
vaulted ceiling lighting sgtrock Building & Construction 0 05-02-2010 07:27 PM
Recessed Lighting Noob Install Question?? help! windycitystyle Electrical 1 01-20-2010 12:53 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 03:52 PM
