Old 03-22-2012, 11:01 PM   #1
Installing recessed lighting
I plan to install a couple of Halo H7RICT cams to be in contact with insullation. Can the cams touch plastic covered air duct tubing? The space is tight.
Pat Mendo is offline   Reply With Quote
Old 03-23-2012, 07:39 AM   #2
You will need to check with the manufacturer of the ductwork to see if it is rated for that or see if there is any ratings printed on the ductwork itself.
danpik is offline   Reply With Quote
bedroom recessed lighting advice wanted andrewbp Remodeling 2 09-30-2011 10:11 AM
Hitting a Joist when installing a recessed light? hicksjh Electrical 9 11-22-2010 09:27 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 05:46 AM
