Installing A Recessed Light - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 11:05 PM   #1
Installing a recessed light
Is it okay to replace a light on a 12 awg circuit (20 amp breaker) with a recessed light that is marked 14 awg through branch circuit conductors (on the can). If not, can you explain why.
y_wren is offline   Reply With Quote
Old 11-13-2008, 11:26 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Does it have pig tails that are 14 gage or are the terminals are it marked that it only accepts 14 gage?
Jamie
jamiedolan is offline   Reply With Quote
Old 11-13-2008, 11:51 PM   #3
Hi,
On the under side of the recessed can is states 'Max. of (4) NO. 14 AWG thought branch circuit conductors 2 in and 2 out suitable for at least 75 degree premitted in junction box.'
Old 11-14-2008, 04:55 AM   #4
DIYer
That sounds like a physical fill limit, not anything to do with ampacity.
Gigs is offline   Reply With Quote
Old 11-14-2008, 08:10 AM   #5
Where will this can be located in the circuit?
rgsgww is offline   Reply With Quote
Old 11-14-2008, 09:50 AM   #6
Hi,
The light is in the middle of run. I have not removed the old light yet, but it is also connected to a 3-way switch. So depending on how this way done, it is possible to have 2 - 12-3 coming from the switch and 1 -12-2 leaving which would exceed the capacity of box. (but I might can do a work around if it'sonly a capacity issue).
Old 11-14-2008, 10:47 AM   #7
Rewards Points: 2,350
Yes, the 14 gauge limit is the volume capacity of the junction box attached to it. I doubt that the 3-way wiring passes through the lights. If the box is limited to four 14-2's, that seems to indicate a volume of 18 cubic inches or so, not counting the wires to the fixture. This would indicate a maximum of three 12-2's in the box.
Installing recessed light trim helpless handyman Electrical 18 07-30-2009 05:35 PM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 07:53 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Recessed light plan foiled? kcrossley2 Electrical 8 03-15-2007 12:08 AM
recessed light farrington135 Electrical 3 12-03-2006 01:02 PM
