Installing A Pull Chain Ceiling Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 11:24 AM   #1
Installing a pull chain ceiling fixture
I was attempting to install a new ceiling fixture over the sink...just a simple globe fixture. However the switch that turns that light on also turns a light on over the bar. I had wanted to put a ceiling fan over the bar so the only way I knew to be able to use one or both was to change the fixture over the sink to one that has a pull chain, that way if I wanted it off and the ceiling fan on, I could turn it off with the pull.
I took the old fixture out noticing that there were two black wires together, one white wire and two bare ground wires. I hooked the new pull chain fixture the same way and it didn't work, so we thought maybe it just wouldn't accept a pull chain fixture, so I put the old fixture back up...the two black to the one black, the one white to the one white and a ground on the fixture to the two ground wires....and now neither that light nor the one over the bar will come on. We checked the breakers and they all appear to be fine. It is a mystery to me why nothing will work no...nothing else in the house is not working. Any ideas what might be the problem?
Thank you,
Floyd Orr
safron is offline   Reply With Quote
Old 08-22-2011, 11:38 AM   #2
Code05's Avatar
Rewards Points: 1,104
You are missing a white wire.
Any other wires in the box?
This romex I assume.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
safron (08-22-2011)
Old 08-22-2011, 11:38 AM   #3
Licensed electrician
Rewards Points: 1,266
The connections sound correct. Have you checked the bulb?
safron (08-22-2011)
Old 08-22-2011, 11:53 AM   #4
Code05's Avatar
Jim, assuming two romex cables.
2 hots, 1 neutral, 2 grounds.
I would say something is screwy.
safron (08-22-2011)
Old 08-22-2011, 12:09 PM   #5
That is the way it was when we took the old one down and it had worked fine....there was a little piece of white wire about 4 inches long but it just fell out and wasn't attached to anything
Old 08-22-2011, 12:12 PM   #6
yes...the bulbs were fine...even if they had been bad for some reason...the other light over the bar would have lit up...both were dead
Old 08-22-2011, 12:14 PM   #7
We figured there were two black and two ground because when the switch is turned on, the light over the sink and the bar come on at the same time...so it would appear that is what connects them to the switch
Old 08-22-2011, 12:16 PM   #8
Yes, it appears to be romex...is it possible that if we pulled the entire wire down a little...there might be another white wire too...strange that both lights worked prior to taking it down...it's a mystery
Old 08-22-2011, 12:34 PM   #9
Code05's Avatar
You have a broken neutral wire. The cable that has only a hot and ground has a white wire that broke off. You need to pull some slack and reattach.
safron (08-22-2011)
Old 08-22-2011, 12:35 PM   #10
I missed that it was only one white. The white piece that fell out is likely the incoming white to complete the circuit. Is there a white stub still in the box?
safron (08-22-2011)
Old 08-22-2011, 12:36 PM   #11
Code05's Avatar
yes there is a white wire in that cable. reattach it.
safron (08-22-2011)
Old 08-22-2011, 12:37 PM   #12
Thank you...so it should work if I have two white, two black and two ground from the recepticle and attach them to the fixture???
Old 08-22-2011, 12:40 PM   #13
I will have to pull the romex out a little and see...strange this is that the piece of white that fell out didn't give the appearace that it was ever attached to anything...not crimped at all
Old 08-22-2011, 12:42 PM   #14
From what I am getting from all the replies is that in that cable...I should see two wires each of white, black and ground...and if we put them together and attach them to the new fixture...we should be ok? We will pull that romex down a little and see if there is another white...thank you
One other question...the original fixture was turned on by the wall switch that turned on both lights...does it cause a problem that I am wanting to replace that fixture with a pull chain one...wouldn't we still use the wall switch to keep the power on to both lights and use the chain to turn the one over the sink on and off and use the pull chains on the ceiling fan that we want to put over the bar to turn it on and off...should we not be trying to put a pull chain fixture in place of the original one? I wouldn't think that should have made a difference though.
Old 08-22-2011, 01:17 PM   #15
Code05's Avatar
Fix white wire. Pull chain is fine.
safron (08-22-2011)
Installing a ceiling fan in a 1925 ceiling DenverBob Electrical 10 03-08-2011 07:30 PM
pull down ceiling storage crimsonalucard General DIY Discussions 16 02-27-2011 09:39 PM
ceiling fan 3rd pull chain starkenwolf Electrical 3 12-18-2010 02:40 AM
Installing upper cabinets when ceiling is not level bhuck Carpentry 7 07-31-2010 10:21 PM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 10:43 PM
