Installing A POT ADSL Splitter - Electrical - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 03:43 PM   #1
Rewards Points: 160
Installing a POT ADSL splitter
I bought the Wilcom PS-32 and was making sure my installation is correct. Do I just connect the blue and blue/white to the "line" then have ATU-R go to the modem and I have the PHONE line going to a hub.
http://www.amazon.com/Steren-FastHom...=telephone+hub
This is the splitter Im using http://www.wilcominc.com/Item.cfm?ProdID=102
Is it ok to connect the DSL line to the telephone hub?
Installing a POT ADSL splitter-20130418_190741.jpg   Installing a POT ADSL splitter-20130418_190751.jpg
word2yamutha is offline   Reply With Quote
Old 05-13-2013, 04:46 PM   #2
Rewards Points: 6,652
As long as it works, and does not drop Internet when you pick up the phone, you did it okay.
Old 05-13-2013, 04:53 PM   #3
Rewards Points: 758
Yup, that's all you have to do. I have the same splitter and it connects to a distribution block for the phone jacks. ATU-R goes to the modem.
AandPDan is online now   Reply With Quote
Old 05-13-2013, 05:32 PM   #4
Rewards Points: 160
So I connect the blue and blue/white wire from the telephone companies side to the "LINE" or do I need to make a run with cat5 from the red and green bolt to "LINE?" Does it matter which pair of wiring I use for the DSL line?
Old 05-13-2013, 05:54 PM   #5
Rewards Points: 758
The left side of the NID is for the telephone company. You shouldn't even be in there.
Your connections are on the right side of the NID, the red/green screws that you see.
If you want to run a new line to those screws go ahead. If using Cat 5, the standard color code for the 1st telephone line would be the blue and blue/white pair. Connect them to the "line" on your splitter.
Old 05-13-2013, 06:29 PM   #6
Rewards Points: 160
Ok that makes sense. So from there I should have 2 separate cat5 wires one for DSL and the other for VOICE. Is it ok to terminate the voice in lets say the blue pair and the dsl in the green pair? I was hoping my hub would allow me to do this. Thanks for the help so far.
Old 05-13-2013, 06:34 PM   #7
Rewards Points: 758
Are you installing the splitter in the NID?
Usually you run a line into the house, directly into the splitter. From there you run a line (or just plug in) your DSL modem. You then run another line from the splitter to your phone "hub."
Old 05-13-2013, 07:02 PM   #8
Rewards Points: 758
Your "hub" should be internally wired. You only need two of the lines.
Cat 5 - blue/white = old GREEN (TIP)
Cat 5 - blue = OLD RED (RING)
You should try to minimize connections on the ATU-R side. Run a wire to it directly.
Something like this:
Old 05-13-2013, 07:10 PM   #9
You want to run a CAT5 from the Telco Network Interface to the input on your splitter. From that point run a CAT5 to your DSL modem. It must be a dedicated isolated line, not one used for anything else. Run the telephones from the station screws on your splitter to your telephones. All lines should be home runs, not some rat's nest splice job. Never run another wire from an existing telco block in the house somewhere. It creates repair issues and is impossible to troubleshoot later without going crazy.
The green (Tip) and the (RED Ring..Voltage) should correspond with the white/blue (tip) and blue/white (ring). They are the same beginning sequence of different era cabling. So, BLUE, ORANGE, GREEN, BROWN is the correct sequencing of the remaining wires in the CAT5. So next would be white/orange (tip), orange/white (ring), etc. Each separate pair can be used for different things, for example the blue pair can be used for data and the orange pair for regular telephone service.
You can multiple the telephone lines for just plain telephones all the way to the Filter.
I rewired my son's house in Colorado when I visited. He had a rat's nest mess with splices everywhere. He also had DSL service that was limping, dropping connections and really slow. Data needs ONE path to the DSL modem without splice legs to function correctly. Otherwise you get reflection of the signal and poor or no service.
His internet is flying now with no issues. I was a telco guy for 30 years.
db3058 is offline   Reply With Quote
Old 05-13-2013, 09:13 PM   #10
Rewards Points: 160
Ok thanks for the tips guys. So from the splitter is a dedicated line to the modem. Is it ok to have a run for the dsl line to a rj 11 jack? Then connect the modem with regular phone wire? The splitter I purchased doesn't have jacks to terminate on. I guess I could just return it and get the indoor PS-36 Wilcom model.
Old 05-13-2013, 09:19 PM   #11
Rewards Points: 66
Yep that's how they did mine years ago. Dedicated dsl line to the inside from the outside panel. No need for filters on phones.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 05-13-2013, 09:25 PM   #12
The filter is so you don't have to place dsl filters on every telephone jack in the house.
Old 05-13-2013, 09:36 PM   #13
Rewards Points: 758
Yes, you can run a line to an RJ-11 jack.
Old 05-14-2013, 07:40 AM   #14
Now of course, the only thing that I can think of, if you are in an area that gets a lot of lightning strikes, is maybe pay the $39 for the L-Com DSL Surge Protector http://www.l-com.com/surge-protector...rge-protectors They make them for CATV & Satellite also. We do not get very many lightning strikes, but I have been thinking about one for the DSL line, due to we have problems with fuzzy tailed tree rats causing power outages, and have had a surge or two.
Old 05-14-2013, 12:01 PM   #15
Rewards Points: 160
The dsl splitter I have comes with a surge protector as well. Better safe then sorry I always say.
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 02:21 PM
Separate ground rod for coax splitter? sheslostcontrol Electrical 35 01-01-2012 08:48 AM
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
