Installing Outlets On An Overhang - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 07:36 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
installing outlets on an overhang
What is the best way to install an outlet in an overhang, when I don't have good access to it from inside the house? I have enough access to run the wire through the attic but not to actually get in to do work. Would I just remove the facia, then install it then cut a hole? Any particular codes for this? Guessing it would have to be a GFI and use a plastic box and not a metal one. What about wire, can I still use regular 14/3 romex (would be in the attic)? I want to install one so I can plug in Christmas lights as it will go better then running a long extension cord, and I could even install a switch somewhere in the house to control it, or even have a little box somewhere where I can hookup a timer. Probably wont take on this project this year though but just toying with the idea of doing that. This should be standard on all houses.
Old 08-09-2009, 07:41 PM   #2
Electrical Contractor
kbsparky's Avatar
Plastic or metal box, doesn't matter. As long as it is sufficiently large enough to hold the number of conductors and the device.
Fishing the wire thru the attic is the procedure we would use on such projects.
-KB
Old 08-09-2009, 08:13 PM   #3
I usually will cut the box in from outside
Use conduit to push feed the wire thru into the attic (before installing box)
Then remove the short section of conduit from the attic
Wire & connect etc etc
Make sure its GFCI protected
Have you seen my thread on my Christmas setup?
I'll have 20 circuits eventually
8 will be controlled by hard wired timers
My attic will have 4 circuits just for my roof display
I'm running a new circuit for window candles - 1 outlet near each window
http://www.diychatroom.com/f39/why-i...ircuits-50297/
Old 08-09-2009, 08:41 PM   #4
Wire Chewer
Rewards Points: 126
Wow that's an impressive Christmas display. I have plenty of storage space in my crawlspace, so I could potentially try to pull something like that off without worrying too much about storage. For the inflatables, do you need to continuously run the blower or can you get away with blowing it up once and sealing it off? I would imagine it to be loud if all of them have to run constantly.
Old 08-09-2009, 09:38 PM   #5
The inflatables need to run constantly
They use between 75w and 140w for the bigger ones (2 fans)
Some of the smaller 4' inflatables use less then 75w
I've had up to 30 inflatables running at once
But they are a pain to dry & pack away in cold weather
So now only maybe 18 or so at a time
I rotate the ones I use - different each year
I have 2 gargoyles that go on the roof plus a skull
They are actually mounted on skids
Old 08-09-2009, 09:51 PM   #6
Requirements for outlet box in overhang
...And it would have to be of the weather-proof type with cover and threaded fittings. (IMHO, and NEC)(Now more than ever) Don't Drink and Drive!!! (Sorry. Couldn't retrieve the "Drinking Icon")
spark plug is offline   Reply With Quote
Old 08-09-2009, 09:57 PM   #7
Celebrating early Christmas
To Posts #3 &#5 Scuba Dave. Are you celebrating Halloween & Christmas together? IN AUGUST???!(Now more than ever) Don't Drink and Drive!!!
Old 08-09-2009, 10:00 PM   #8
I'm not sure what you mean?
Old 08-09-2009, 10:09 PM   #9
Wire Chewer
Rewards Points: 126
I'm pretty sure he's posting pictures from past decorations, not current ones.
Though, with the weather where I am, it's tempting to put up the lights in preparation for Christmas, and put up the Halloween and thanksgiving deco up now. Leafs are slowly starting to change color so it's a sign. Then again Summer will in fact be over in a few weeks for us.
Old 08-10-2009, 12:14 PM   #10
Registered User
Rewards Points: 5,516
If you have storage in the attic, you will want to protect the cable run with boards or 2x next to it so as not to put anything on the cable. At least within 6' of the attic scuttle, as per code (320,30.34.23), to protect against fire danger. Be safe, G
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
tight overhang clearance on gable abutment - how to cover...? rtoni Roofing/Siding 7 10-11-2007 11:13 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
