Installing Outlet In Kitchen Island - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 12:37 PM   #1
installing outlet in kitchen island
Hello,
I have a moveable kitchen island and I'm going to be installing an electrical outlet in it. In order for it to become "permantly fixed" I will be putting a bead of clear silicone caulk all around it so it doesn't move, the wire will run down the inside of the island in a metal wiring tube and go through ceramic in a junction box in the ceiling of the basement, from there I will connect it to another electrical wire to the main panel. This way if for some reason the island falls over or some crazy thing like that, the wire gets disconnected at the junction box where the stress occurs rather than pulling on the main panel.
I guess my questions are 1. would the silicone method be enough or do I need to do more to make the island permanent
2. what do you guys think of the wiring method?
ps: what would you guys use to drill into the ceramic?
indep is offline   Reply With Quote
Old 01-14-2013, 01:02 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Wether or not silicone hold remains to be seen. I would use a more permenant method. You did not mention the actual wiring method. IF you use romex it has to be protected from physical damage. This "metal pipe" may or may not be adequate. AS for drilling the ceramic tile, use a diamond or carbide tip bit.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-14-2013, 01:37 PM   #3
thanks for the reply, yes it will be rommex, and the metal tubing is that round metal shield for exposed wires.
What permanent method would you use? it's sitting on ceramic currently
Old 01-14-2013, 01:41 PM   #4
electures's Avatar
Screw a couple of 2x4 to the floor and secure it to them.
Installing a dedicated outlet in basement Robes888 Electrical 7 12-01-2011 03:31 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
kitchen island outlet wiring problem colarama Electrical 3 09-22-2011 05:51 AM
Kitchen Island sink odor SixStrRzr Plumbing 12 02-10-2011 06:45 PM
kitchen Island outlet richardremodeler Electrical 8 06-05-2007 05:45 PM
