Installing Outlet In Island - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 08:32 AM   #1
Rewards Points: 155
installing outlet in island
Getting ready to install the island- Electrical cable was run to the area for the island and I have installed the outlet box in the cabinet. What is best way to fasten the romex to the inside wall of cabinet since it's not like using cable stapes on a wall stud (cabinet wood much thinner)- Is there a recommended way of keeping the cale nice and neat?
Huskyfan68 is offline   Reply With Quote
Old 11-30-2012, 09:50 AM   #2
joed's Avatar
Rewards Points: 13,768
Use cable staples that will not go out the other side.
Old 11-30-2012, 10:14 AM   #3
TTW
TTW's Avatar
Why not fit a board, say, a 1x3 pine inside the cabinet where the wire runs, and staple to that?
TTW is offline   Reply With Quote
Old 11-30-2012, 03:22 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
Sleeve the cable with FNMC ( Seal-tite) and use 2 hole straps and short screws. Some inspectors will fail unguarded NM in a cabinet as not be protected from damage.
Coastal South Carolina
The Following 3 Users Say Thank You to rjniles For This Useful Post:
funfool (11-30-2012), Oso954 (11-30-2012), TTW (11-30-2012)
Old 11-30-2012, 04:06 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
FNMC is not protecting the NM, so why they would allow that is beyond me. Most Chapter 3 wire methods all require protection from physical damage, so to me, encasing the wiring method in concrete is the only solution.
Old 11-30-2012, 04:09 PM   #6
E2 Electrician
I just use these... I dont sleeve my NM in anything, I just route it away from physical damage locations.
Old 11-30-2012, 04:20 PM   #7
Rewards Points: 332
I sleeved mine in "smurf tube" and used the screw down clamps.
sgip2000 is offline   Reply With Quote
Old 11-30-2012, 04:22 PM   #8
A "Handy Husband"
rjniles's Avatar
Originally Posted by stickboy1375 View Post
I just use these...
What are those? A cable tie with a screw hole? Got a link?
BTW, tough to keep that concrete in place around the cable.
Old 11-30-2012, 04:23 PM   #9
E2 Electrician
Just google cable ties with a hole...
Old 11-30-2012, 04:24 PM   #10
funfool's Avatar
Rewards Points: 534
Is required to put them in something here, our electrician uses the flexible metal conduit.
I cant think of proper name for it right now, flex and a couple short screws with a c clamp.
funfool is offline   Reply With Quote
Old 11-30-2012, 04:27 PM   #11
A "Handy Husband"
rjniles's Avatar
Greenfield is a trade name commonly used.
Old 11-30-2012, 04:29 PM   #12
E2 Electrician
FMC (flexible metal conduit) requires protection from physical damage, just like NM (romex) wire does... this is why its stupid from a code point for an inspector to not allow NM but to allow FMC in a cabinet, personally, there is no physical damage in a cabinet to begin with...
Installing a ceiling light. No outlet box bergmanmh Electrical 5 03-25-2012 01:30 AM
Installing outlet...please help H2O Engr Electrical 4 02-15-2010 11:06 AM
Installing 120VAC Outlet DK75 Electrical 4 11-26-2007 03:51 PM
Help on installing a 220v outlet BobRankin Electrical 24 10-23-2007 05:32 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
