-   -   installing outlet in island (http://www.diychatroom.com/f18/installing-outlet-island-165150/)
Huskyfan68 11-30-2012 08:32 AM
Getting ready to install the island- Electrical cable was run to the area for the island and I have installed the outlet box in the cabinet. What is best way to fasten the romex to the inside wall of cabinet since it's not like using cable stapes on a wall stud (cabinet wood much thinner)- Is there a recommended way of keeping the cale nice and neat?
joed 11-30-2012 09:50 AM
Use cable staples that will not go out the other side.
TTW 11-30-2012 10:14 AM
Why not fit a board, say, a 1x3 pine inside the cabinet where the wire runs, and staple to that?
rjniles 11-30-2012 03:22 PM
Sleeve the cable with FNMC ( Seal-tite) and use 2 hole straps and short screws. Some inspectors will fail unguarded NM in a cabinet as not be protected from damage.
stickboy1375 11-30-2012 04:06 PM
12 Attachment(s)
FNMC is not protecting the NM, so why they would allow that is beyond me. Most Chapter 3 wire methods all require protection from physical damage, so to me, encasing the wiring method in concrete is the only solution. ;)
stickboy1375 11-30-2012 04:09 PM
12 Attachment(s)
http://www.cable-ties.com/images/cnt...talog/mhct.jpg
I just use these... I dont sleeve my NM in anything, I just route it away from physical damage locations.
sgip2000 11-30-2012 04:20 PM
I sleeved mine in "smurf tube" and used the screw down clamps.
rjniles 11-30-2012 04:22 PM
Originally Posted by stickboy1375 (Post 1063770)
What are those? A cable tie with a screw hole? Got a link?
BTW, tough to keep that concrete in place around the cable.
stickboy1375 11-30-2012 04:23 PM
12 Attachment(s)
Just google cable ties with a hole... :)
funfool 11-30-2012 04:24 PM
Is required to put them in something here, our electrician uses the flexible metal conduit.
I cant think of proper name for it right now, flex and a couple short screws with a c clamp.
rjniles 11-30-2012 04:27 PM
Greenfield is a trade name commonly used.
stickboy1375 11-30-2012 04:29 PM
12 Attachment(s)
FMC (flexible metal conduit) requires protection from physical damage, just like NM (romex) wire does... this is why its stupid from a code point for an inspector to not allow NM but to allow FMC in a cabinet, personally, there is no physical damage in a cabinet to begin with... :no:
