Installing Outlet On Existing Drywalled Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 09:36 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Installing outlet on existing drywalled wall
I want to install a 20 amp outlet on an outside wall for my AC unit as it draws 14.5 amps on it's own, so I don't really like using an extension cord for something like this. I've installed network jacks before, I trace the cut out, use drywall knife to cut hole, get a long drill bit and drill downwards then try to find the hole in the basement and fish the wire through.
For electrical is it pretty much the same idea? Any special considerations? I assume I need to use an "old work" plastic box rated for electrical, as opposed to the ones I use for networking which is just a small plastic frame that screws in and locks into the drywall. Does it need to be against a stud?
Lastly, any new special codes for outside walls, or can I still use standard 12/2 romex for this?
Old 05-31-2010, 09:55 PM   #2
Use an electrical cut-in box. Since the outlet itself will be inside the house you don't need any weatherproof equipment. If it's a dedicated circuit use a simplex receptacle sized equal to the breaker and wire. See the other thread for more info on that.
fpeftw is offline   Reply With Quote
Old 06-01-2010, 06:52 AM   #3
Just call me Andrew
Rewards Points: 1,020
I fish wire with a magnet, it works well - though it may be more difficult in an insulated wall. After you drill your hole in the basement and cut the hole for the box, tape a rare earth magnet to a string. Drop it into the wall. Have a friend stick a fish tape (metal) into the stud cavity in the basement. You can shacke the string around till the magnet grabs the fish tape. Then he pulls the fish tape out (with the string attached). Next you tape the romex to the string, and pull it through.
Andrew
secutanudu is offline   Reply With Quote
Old 06-01-2010, 03:17 PM   #4
Wire Chewer
Rewards Points: 126
Nice idea with the magnet, wish I would of thought of that when fishing my thermostat wire, ended up cutting a hole in drywall just so I could put the wire into the hole, seemed like a waste haha.
I'll buy an old work box and get going, I checked a few tutorials online and it looks like it's similar to putting a network jack.
Old 06-01-2010, 05:30 PM   #5
Electrician
Rewards Points: 794
How do you plan on putting vapour barrior around your box and keep it contonious after you cut the box in. This is the main reason i try never to cut a box into an outside wall.
darren is offline   Reply With Quote
Old 06-01-2010, 05:42 PM   #6
Master Electrician
Rewards Points: 3,870
Just how do maintain your vapor barriers on new construction when the rock goes up and the boxes are cut out with a router?
brric is online now   Reply With Quote
Old 06-01-2010, 08:12 PM   #7
Electrician
Rewards Points: 794
I never thought of that before, now you makeing me think on how they do it.
Old 06-01-2010, 08:57 PM   #8
Master Electrician
There are ways and devices to do it but it's rarely done in my area.
An 8 square inch hole in the drywall is quite irrelevant in my opinion.
Old 06-02-2010, 05:30 PM   #9
Electrician
Rewards Points: 794
We always put vapour barrioer around the box, they tape it to there vapour barrier when they do the wall. As the drywall goes up they cut around the box and i just assumed that the vapour barrier was not cut but it may get cut when they go around the box.
Old 06-02-2010, 07:14 PM   #10
Wire Chewer
Rewards Points: 126
When I did my network jack, I ripped the vp a bit while drilling and fishing the wire, when I was done I just tapped it up as best as I could with red tape, then installed box and jack plate.
Oh and you guys will like this, it took 3 home depot staff to help me find an old work box LOL. They only have metal ones too. I was hoping for a plastic one, as I'm pretty sure there's a new code now to use plastic for outside walls. Whenever I google anything electrical related I always see blue plastic boxes, but they don't seem to have those anywhere here.
Old 06-02-2010, 08:05 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Hey, nobody here told you you have to live in Canada!! We have plastic cut in boxes at local grocery stores even.
just kidding, but they are very commonly found at any big box store around me.
Old 06-02-2010, 08:25 PM   #12
Wire Chewer
Rewards Points: 126
Maybe plastic boxes crack in the winter here or something, so metal is the only way to go LOL.
Old 06-03-2010, 04:37 PM   #13
Electrician
Rewards Points: 794
Theres no code rule saying you have to use a plastic box on an outside wall. You rarely see plastic boxes in Canada, I'm not even sure if Home Depot would carry them.
Old 06-03-2010, 10:52 PM   #14
Wire Chewer
Rewards Points: 126
Good to know. Someone told me it was a new code, but could be they were wrong, or maybe it was a recommendation, and not a code. But yeah I did notice plastic boxes are hard to find. They have plenty of the outside ones that use conduit though.
I'm also debating on putting the outlet on the inside wall instead. Will require me to have the AC cord across the closet door though, but it will be so much easier to fish the wire and the closet door can still open no problems.
Old 06-04-2010, 06:53 PM   #15
Rewards Points: 518
Here in Alberta plastic boxes are rare as well. Home Depot and Rona usually have a very few select models on hand at 4 times the price of a metal box. Just FYI.
n0c7 is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
How to place a new wall in a continuous mathematical alignment with existing wall Frye Building & Construction 9 03-31-2010 09:11 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing outlet...please help H2O Engr Electrical 4 02-15-2010 11:06 AM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
