Installing Outdoor Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 07:44 AM   #1
Custom User Title
Rewards Points: 252
Installing outdoor outlets
I'm going to install 2 outdoor outlets. What size wire and breaker?
I'm planning on running both outlets to a new arc fault breaker since they are now code here. Should I use 15 or 20 amp? I also understand that you don't need a GCFI outlet now if you use an arc fault breaker. Is that correct?
What size wire? I'll be using the gray UF, my brother says I should use 12-2 but its twice the price of 14-2. Which one should I do?
no1hustler is offline   Reply With Quote
Old 03-22-2013, 07:55 AM   #2
Rewards Points: 13,994
Why would you use UF wire? If the wires not being run under ground it's not needed and would be a whole lot harder to work with.
Yes your going to need a GFI.
If it was mine I would use 12-2, 20 amp breaker, and try and find a way to have the GFI on the inside of the house in an easy to access place then run the wires to the outside outlets. Reason being you'll get a lot less faulse trips from moisture.
I'd use the 20 amp. because at some point someone's going to try and run a compressor, ciruler saw or some other tool while doing repairs and it may keep tripping.
I'm hoping some of the real electritions will chime in on having to have that on an Arc fault.
no1hustler (03-22-2013)
Old 03-22-2013, 08:11 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
Are you running new receptacles on the outside of the house, or out into the yard?
Gfci are required in either case.
Size of wire and breaker is determined by what you will be using the circuits for.
20 amp breaker with #12, 15 amp with #14.
UF cable can be run underground, or you can run pipe and use individual wires.
AFCI is not required for outside receptacles.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
joecaption (03-22-2013), no1hustler (03-22-2013)
Old 03-22-2013, 09:21 AM   #4
Custom User Title
Rewards Points: 252
Great. Thanks guys. I just did some more reading on the subject. You guys are right. AFCI is not required for exterior receptacles. I'll have to tell my brother that!
The wire is not going directly into the back of the box. It will be exposed to the elements so that is why I planned on using UF.
I'll use 20amps with #12. Joe is right, I'll be using some stuff with high loads on occasion.
Which is better, plastic or metal boxes for outside?
Old 03-22-2013, 09:26 AM   #5
Plastic, it would be great if you would tell us exactly how you plan on doing this so no one has to guess.
Are you installing the box on the outside of a building, out in the yard on a pole?
Old 03-22-2013, 09:34 AM   #6
Custom User Title
Rewards Points: 252
Oh sorry. I'll be drilling through block to the outside (at an angle so water won't try to get in). Running the wire out the hole and up into the bottom of the box which will be attached to the outside of the house. I'll seal the hole that the wire is coming through. I'll do that on the front of the house and the back. I'll run them both directly into the circuit box on its own breaker. Down the road I'll probably add an additional outlet on a post out in the yard but that is for another time. Out front I may hard wire a spotlight to the outlet.
Old 03-22-2013, 09:42 AM   #7
I'd use a box like this and feed it from the back side through a piece of PVC.
http://www.homedepot.com/p/Greenfiel...23PS/202188611
Old 03-22-2013, 10:07 AM   #8
Custom User Title
Rewards Points: 252
I can't go directly into the back. I'll be coming out of the block wall and the box will be attached to the brick above where it comes out. Otherwise, the box would be too low to the ground for my liking.
Old 03-22-2013, 10:11 AM   #9
Then you use one of these where it comes out of the wall and some PVC conduit with a water tight adapter on the bottom of the box.
http://www.bing.com/images/search?q=...electedIndex=1
When drilling the hole through the block make sure to drill it from the outside in. If not your going to blow the block out.
Use Tap-Con screws to attach to the wall.
Old 03-22-2013, 10:15 AM   #10
Custom User Title
Rewards Points: 252
If I do that instead, can I nix the UF?
Old 03-22-2013, 11:36 AM   #11
Yes, not suppost to have it exposed outside where it can be damaged any way.
Old 03-22-2013, 11:40 AM   #12
jbfan's Avatar
Rewards Points: 546
No.
If you went into the back, you would not have to use the uf, but since there will be a piece of pipe, nm-b can not be used.
A conduit outside is considered a wet location and nm-b can not be used in a wet location.
You could put a junction box inside, and bring individual wires from there to the receptacle.
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 09:54 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 07:38 AM
Installing T&G birch ceiling NeedHelp Building & Construction 6 12-29-2007 08:09 AM
