Installing An Outdoor Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 08:46 AM   #1
Question
Installing an Outdoor Outlet
I need to install an outdoor outlet for my patio and I have a couple of questions. I know I need a GFI outlet but I'm not sure about any other codes for Dallas, TX.
1. Can I tie the outlet off the dishwasher outlet which is on the inside wall or is this bad practice?
2. How far away from the outside water faucet do I need to be? The location I'm looking at it about 2ft away.
Thanks.
gneirynck is offline   Reply With Quote
Old 08-25-2010, 10:00 AM   #2
Kitchen outlets are off limits, can't use them
Laundry & bathroom also no go
Basement is OK
You need an in use wet cover
I usually put a GFCI outlet inside & feed a normal outlet outside
There isn't really a distance from the hose required
The further the better so you don't trip it
Since its GFCI protected its OK
Old 08-25-2010, 10:38 AM   #3
Rewards Points: 746
The dishwasher receptacle (if it's not hard-wired) is not a wall receptacle as covered in 210.52(a) and is not subject to to the kitchen only restriction. It is however limited by restrictions on general branch circuit loads.
Mark
busman is offline   Reply With Quote
Old 08-25-2010, 11:45 AM   #4
Just call me Andrew
Rewards Points: 1,020
I would advise against using the dishwasher circuit even if it's allowable in the NEC...you will likely be using power tools outside while the DW is running - may lead to annoying breaker trips.
Andrew
secutanudu is offline   Reply With Quote
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 12:59 PM
