Installing Outdoor Motion Detector/Light??? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 01:25 PM   #1
I'm replacing an old motion sensor/light with a new one. Here is the issue:
I removed the old fixture and discovered two sets of feed wires coming from the house to the fixture. First, black/white/green going to the light. And then separately, black/white/red going to the motion sensor. Six wires total.
The new fixture has only a black/white/ground. The motion sensor wires are "pigtailed" into the wires to the light.
How do I wire this new fixture to the existing wires?
I tried doing all whites together, all ground together, and then black (old light) and black/red (old motion) to the black from the new fixture.
With this configuration, I can hear the motion sensor clicking like it is working, but I get no light.
Any thoughts?
The Third is offline   Reply With Quote
Old 07-24-2010, 03:17 PM   #2
Electrical Contractor
kbsparky's Avatar
Try another bulb ..
-KB
Old 07-24-2010, 07:37 PM   #3
Electrician
Proby's Avatar
kb, you think there might be something more to this?
There is a black and white cable and then a black, red, and white cable. The first cable was connected to the light and the second to the motion detector.
This is reminding me of a remote ballast or relay or something...
I can't see why both blacks and the red should be spliced straight thru.
Proby is offline   Reply With Quote
Old 07-25-2010, 12:47 AM   #4
Just to make sure I'm not missing the simple fix, I'm going to try a new bulb tomorrow!
That said, I'm guessing I've not got this wired correctly.
Any other thoughts are appreciated.
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 10:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 12:11 PM
Installing a new phone jack. Which wiring to use for only 6ft? Help! romo218 Electrical 18 10-03-2009 11:20 PM
installing patio sliding door on concrete pad jwms Building & Construction 6 04-19-2009 01:46 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
