Installing Outdoor GFCI Off Of A Middle Of The Run Existing Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 10:34 AM   #1
Smile
Installing outdoor GFCI off of a middle of the run existing receptacle
I want to install an outdoor GFCI by tapping into an existing receptacle that is middle of the run. I need to know how to handle the wiring. Thanks so much for any and all suggestions.
Noahsark09 is offline   Reply With Quote
Old 11-30-2009, 10:56 AM   #2
Licensed electrician
Rewards Points: 1,486
Certain circuits are limited to specific rooms or functions like the kitchen, bathroom and laundry circuits. Where are you trying to obtain power from?
Old 11-30-2009, 02:36 PM   #3
I am obtaining the power from the existing receptical which is middle of the run.
Old 11-30-2009, 02:47 PM   #4
Right, but where is that circuit located/feeding ?
Normal room, bathroom, laundry room, kitchen ?
There are restrictions on feeding other outlets from certain circuits
Old 11-30-2009, 03:10 PM   #5
Smile
Sorry it is in a bedroom. A spare bedroom that isn't being used.
Old 11-30-2009, 04:02 PM   #6
Yes, you can tap off of a bedroom outlet to install an outside outlet
Outside outlet must be GFCI protected
Old 11-30-2009, 04:11 PM   #7
I am just confused as to how to handle the wiring. I have a line and load and want to know how to wire the new receptacle
Old 11-30-2009, 04:18 PM   #8
300zx's Avatar
Post
Put them under the line- Load would be for other rec's protected off The GFCI'S.
300zx is offline   Reply With Quote
Old 11-30-2009, 04:24 PM   #9
If you want an outside GFCI that will trip independant of the GFCI inside then connect off the LINE side & install a GFCI outside
If you want the external outlet protected off the inside GFCI then connect off the LOAD side
Myself I'd use the GFCI inside
Outside ones now need to be TR (tamper resistant) & WR weather resistant)
This has driven up their cost quite a bit
Old 11-30-2009, 04:31 PM   #10
So basically I just need to pigtail off of the line side and run the electric out to the new GFCI? and leave the load lines alone?
Old 11-30-2009, 04:32 PM   #11
I am wonder about the wiring configuration. I was told to pigtail the line black, and line white. Rewire the existing and run the forth wire out to the GFCI
Old 11-30-2009, 05:01 PM   #12
300zx's Avatar
Post
Yes,You can pigtail and run one wire to GFCI Just hook to line side of Gfci.
Old 11-30-2009, 05:10 PM   #13
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
The recepticles in the bedroom probably do not have a line and a load.
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Installing 24" granite tiles over existing kitchen countertop? pford Carpentry 3 01-25-2008 10:16 PM
Installing 'peal and stick' vinyl squares on top of existing .... alexz Flooring 8 02-17-2007 04:20 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
Installing a Door in an existing pass-through gbarron1 Building & Construction 2 03-17-2005 03:47 PM
