Installing Outdoor GFCI From Existing Indoor Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 04:20 PM   #1
Smile
Any new rules for outdoor GFCI from indoor existing circuit?
Want to install outdoor GFCI from existing indoor circuit. what's the rules?
Ken Barker is offline   Reply With Quote
Old 09-10-2010, 07:15 PM   #2
Licensed electrician
Rewards Points: 1,472
Bathroom, kitchen and dining receptacles circuits are off limits. So is the laundry circuit. Circuits dedicated for appliances fixed in place are also out. Any other circuit with reserve capacity should be ok. The circuit must be grounded.
GFI protection is required outside as well as the weatherproof in use cover.
Installing fiber cement siding over existing siding elsobrider Carpentry 20 08-04-2010 05:34 PM
Installing 'peal and stick' vinyl squares on top of existing .... alexz Flooring 8 02-17-2007 04:20 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
Installing a Door in an existing pass-through gbarron1 Building & Construction 2 03-17-2005 03:47 PM
