Installing Outdoor Floodlight - Almost No Wall Access - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 10:31 AM   #1
Installing outdoor floodlight - almost no wall access
So I installed an outdoor floodlight yesterday, and while planning I realized that there is almost no wall access to where I wanted to put the light.
The situation:
The light is on the outside of a kitchen nook/breakfast area. There is no attic access above the nook (insulation blow in filled the original crawl space). The wall is hexagonal shaped, with windows in each section. The ceiling is arched, and runs well above the roof line outside.
My temporary solution was to piggy back the light off a patio light, and I've used the appropriate UL cable and caulked everything to seal, but I am very unhappy with the solution.
For starters, the box is mounted right to the wall (since I couldn't recess it and still access it). And the wire run from the other light looks ghetto.
Suggestions?
(also hi)
wylker is offline   Reply With Quote
Old 03-15-2010, 12:51 PM   #2
Rewards Points: 1,440
Did you use Wiremold (tm) or other neat looking covering for the cable going to the other light fixture?
I hate fishing wires through walls so I would either leave it as-is or drill a hole straight through the wall and run the cable on the wall surface inside, perhaps to a nearby receptacle to get the power from.
Old 03-15-2010, 12:58 PM   #3
I'm gonna shoot some pictures tonight to show the issues, the answer may be destroying the drywall inside to get outside, then repair =/
Old 03-15-2010, 01:11 PM   #4
I will usually determine where I can run the wire 1st
Then I will install the light
Old 03-15-2010, 01:19 PM   #5
Sorry I thought I was clear in the OP. I decided to run the wire outside, but am unhappy with how it turned out.
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Removing Subfloor for Wall Access Riven02 General DIY Discussions 7 04-17-2009 05:28 PM
installing wall box programmable timer rasta Electrical 8 11-12-2008 09:36 AM
Installing New Wires In Wall? madcitysw Electrical 5 01-14-2008 09:08 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
