Installing OTR Microwave But No Electrical Outlet In Upper Cabinet - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 09-21-2012, 09:41 PM   #61
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
Originally Posted by PoleCat View Post
I DO appreciate the level of dedication that a master electrician has and when they are working an industrial or large scale commercial situation they are earning every cent they are getting. But I just can't get on board with putting the same rate on a hapless home owner for doing what amounts to semi skilled labor. I appologize back for feeling the way I do about that.
"Semi-skilled"??? Are you ****ing kidding me???
WHAT does the scope of the work have to do with it????
The codes are the same. The work is different but essentially the same.
WHY are you putting ind work on a pedestal and dismissing resi work as paltry?
What about those of us who are skilled on several levels? I can do industrial work and troubleshooting, as well as commercial/retail/non-resi, and also I am extrememly proficiant at all phases of resi work.
Am I an over priced hack only when I am doing resi work?
Your views on things are pretty warped.
Speedy Petey is offline
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
electures (09-22-2012), frenchelectrican (09-22-2012), Jim Port (09-21-2012)
Old 09-21-2012, 09:49 PM   #62
dmxtothemax's Avatar
Rewards Points: 5,100
Originally Posted by salilsurendran View Post
Right now I have the OTR microwave plugged into a wall socket and have been using it for a few days and none of the breakers have tripped. So why would it be a problem if I plug it into a wall socket in the kitchen.
I think you will find that electrical code does not allow
flexable cords to be used as a substitute for proper electrical cable !
Thats why !
dmxtothemax is offline
Old 09-21-2012, 09:51 PM   #63
Registered User
Rewards Points: 5,180
The OP has had the questions answered and it appears to be going off thread, now closed. Gary
Gary in WA is offline
Closed Thread
Outlet Inside Vanity Cabinet - Does It Need To Be GFCI? LowlyDIYer Electrical 18 02-05-2012 09:41 AM
New home with electrical outlet with blk soot Joseph_diy Electrical 6 01-22-2012 08:49 PM
Help with adding electrical outlet bowanna03 Electrical 5 05-23-2010 08:00 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 11:59 PM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 04:46 PM
