Installing OTR Microwave But No Electrical Outlet In Upper Cabinet - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 09-15-2012, 01:17 PM   #1
Rewards Points: 12
Installing OTR microwave but no electrical outlet in upper cabinet
Hello,
I have an OTR microwave but right now I have no electrical outlet in the upper cabinet. I was planning to drill through the side cabinets and use an extension cord to reach the nearest electrical socket. Was wondering if that is a good plan or should I get an electrician to install an electrical socket in the upper cabinet?
salilsurendran is offline
Old 09-15-2012, 03:46 PM   #2
Rewards Points: 216
Not sure where you're located, and I am not an electrician, but in Canada when I installed an OTR microwave(GE) the code was an OTR microwave required a dedicated circuit (15amp). But a stand on the counter microwave could be plugged into a kitchen receptacle. So, here, you'd require a dedicated circuit. But the code may be different for your location.
orange is offline
Old 09-15-2012, 03:47 PM   #3
An old Tradesmen
Rewards Points: 8,168
Moved to Electrical forum.
beenthere is offline
Old 09-15-2012, 03:58 PM   #4
Resi EC
Rewards Points: 252
Best thing would be to get a licensed electrician to install a circuit for the microwave
Gac66610 is offline
The Following User Says Thank You to Gac66610 For This Useful Post:
Speedy Petey (09-16-2012)
Old 09-15-2012, 08:58 PM   #5
kevinp22's Avatar
Rewards Points: 252
dont use an extension cord for a permanent load, especially a high draw appliance
kevinp22 is offline
Old 09-15-2012, 09:12 PM   #6
Licensed electrician
Rewards Points: 1,876
You are going to need to install a new dedicated circuit from the panel.
Do not use the extension cord.
Jim Port is offline
Old 09-15-2012, 09:15 PM   #7
Rewards Points: 6,652
Originally Posted by salilsurendran View Post
Hello,
Sure, go right ahead. It is your butt, and not anyone else's, when it goes up in flames.
gregzoll is offline
Old 09-15-2012, 11:20 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Est-ce que vous êtes sérieux ?
( are you serious ? )
The OTR microwave unit will required it own circuit anyway. This useally mention in the owner manual or installment sheet.
Merci,
Marc
frenchelectrican is offline
Old 09-16-2012, 02:19 AM   #9
Rewards Points: 12
Right now I have the OTR microwave plugged into a wall socket and have been using it for a few days and none of the breakers have tripped. So why would it be a problem if I plug it into a wall socket in the kitchen.
Old 09-16-2012, 06:46 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
I can already see where this is going.
A breaker will not trip and your house will not burn down the instant you plug the thing in. This is a long term problem and the main problem is with the extension cord going through cabinets. Also the fact that you are plugging in a larger fixed appliance to a wall or counter circuit.
I get the impression that it works now so you think everything is fine and nothing bad will happened. You can think this and will probably do what you want anyway, but please know that the others here are absolutely CORRECT. You NEED a dedicated properly sized circuit in the cabinet above the micro/hood. This is the ONLY safe, proper and legal solution.
Speedy Petey is offline
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (09-16-2012), Jim Port (09-16-2012), kevinp22 (09-16-2012)
Old 09-16-2012, 07:35 AM   #11
Merci,
Marc
Marc, it is called Sarcasm.
gregzoll is offline
Old 09-16-2012, 10:20 AM   #12
PoleCat's Avatar
Rewards Points: 1,652
Hey I got to agree with these other fellers about just putting in a new circuit. It is the only right way to do it. But having resorted to many an act of disregard for the accepted convention myself I can understand your position. If I were hell bent on using the extension cord I would only use one rated for the same current as the breaker on that circuit. And I would check to see if Green Acres type precautions were needed such as never running the microwave while the coffee pot was on or the toaster was in use. Newer microwaves don't chug as much juice as they used to and you may get lucky and have no serious issues.
PoleCat is offline
Old 09-16-2012, 10:40 AM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
I don' think we should encourage posters to disregard code and safety issues.
Coastal South Carolina
rjniles is online now
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Old 09-16-2012, 11:11 AM   #14
Goto your hardware store get a 120 volt cord for a microwave. There are some that are made specifically for microwaves. You do not need a dedicated circuit as a otr microwave does not have any more wattage than an on the counter microwaves
mike.nowak is offline
Old 09-16-2012, 11:15 AM   #15
WRONG!
Please learn the codes before posting electrical advice to this board.
The Following 10 Users Say Thank You to Speedy Petey For This Useful Post:
Code05 (09-16-2012), electures (09-16-2012), frenchelectrican (09-16-2012), jbfan (09-21-2012), kevinp22 (09-16-2012), Missouri Bound (09-20-2012), Oso954 (09-20-2012), rjniles (09-16-2012), stickboy1375 (09-16-2012), Techy (09-20-2012)
Closed Thread
Outlet Inside Vanity Cabinet - Does It Need To Be GFCI? LowlyDIYer Electrical 18 02-05-2012 08:41 AM
New home with electrical outlet with blk soot Joseph_diy Electrical 6 01-22-2012 07:49 PM
Help with adding electrical outlet bowanna03 Electrical 5 05-23-2010 07:00 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 10:59 PM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 03:46 PM
