Installing New Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 08:23 PM   #1
I'm trying to install a new switch timer but my old switch has 4 wires and the new timer switch has 3. I've included pictures of both. What wires go where?
Thanks,
Brandon
agentbb007 is offline   Reply With Quote
Old 08-22-2012, 08:28 PM   #2
Licensed electrician
Rewards Points: 1,472
You do not have a neutral at your switch. You cannot install the new switch without rewiring.
Old 08-22-2012, 08:29 PM   #3
Oh dang, is that something difficult for an electrician to do or expensive?
Old 08-22-2012, 08:35 PM   #4
All depends on the conditions on site that need to be dealt with.
Can you find the same switch that does not need a neutral?
Old 08-22-2012, 08:36 PM   #5
Ok thanks so much for your help Jim. I will call an electrician to come take a look at it. I also did find a similar switch Honeywell RPLS540A but it says it doesn't work with CFL bulbs but this is for the lights on the front of my house and there are like 5 lights so from what I've read it still might work with CFLs since there are more than 1 of them.
Old 08-22-2012, 08:46 PM   #6
Ok so rather than calling an electrician would this RPLS540A switch work with my current wiring? If so what installation would I follow in the manual:
http://customer.honeywell.com/techli...69-2454EFS.pdf
They list 3 different types of installs.
Old 08-22-2012, 08:55 PM   #7
Lets back up one step. I forgot to ask if there were any other wires in the switch box. I was just going off the ones connected to the switch.
That is a three way switch. Pay attention to the wire connected to the black screw.
Old 08-22-2012, 09:29 PM   #8
Master Electrician
new switch is single pole old switch is a three-way. Might be easier for you to find a switch for the application you want that doesn't require a neutral.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Trouble Installing Dimmer Switch Pfern Electrical 2 06-01-2012 09:24 PM
Installing a NXG Volume Control Switch helpless handyman Electrical 1 04-26-2012 04:01 PM
Installing new switch from an old one. Indecisi0n Electrical 1 10-29-2011 11:33 AM
Tripped breaker installing new light switch? tylermac Electrical 3 02-05-2011 04:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
