Installing A New Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 03:51 PM   #1
Mlwhite's Avatar
Rewards Points: 29
Installing a new switch
I currently have a switch that is controlling the light to two rooms in the basement. One room is finished the other room is just storage and not finished. Can I put a switch in the unfinished storage room to control that light. It looks as if the power runs to the light. Any help would be greatly appreciated.
Michelle
Mlwhite is offline   Reply With Quote
Old 12-30-2011, 04:02 PM   #2
MarginallyQualified
Rewards Points: 2,464
Confirm where the power feeds from ... then put a switch on it.
hth
Old 12-30-2011, 04:06 PM   #3
Mlwhite's Avatar
Rewards Points: 29
Power comes from the light in the next room.
Old 12-30-2011, 04:44 PM   #4
Licensed electrician
Rewards Points: 1,440
If the light in the other room is controlled by a switch so will the new room.
Old 12-30-2011, 04:48 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,152
If the power goes to the light and then loops to the switch,
Then you will have to run a cable from here
to the light in the other room,
then a loop to the new switch.
dmxtothemax is online now   Reply With Quote
Old 12-30-2011, 04:52 PM   #6
Mlwhite's Avatar
Rewards Points: 29
So there is no way to put a switch to just switch the light in the unfinished room without switching the other room also. Thats what I already have and I am trying to remedy.
Old 12-30-2011, 04:56 PM   #7
joed's Avatar
Rewards Points: 12,322
Two different scenarios.
1. You want both light still controlled by the existing switch but you also want the storage switch to control the the one light IF the other switch is on. The storage room can only be turned on if the other switch is already on.
2. You you want complete independent control of both lights.
Either way you need to tall us the cabling between the lights and the existing switch. Which light does the power come into? how many wires(not counting ground) in the cables between the lights and between the lights and the switch.
Old 12-30-2011, 05:36 PM   #8
Mlwhite's Avatar
Rewards Points: 29
Okay at the original switch there are two sets of wires going to the switch, the only thing tied together are the grounds and white wires. This switch controls two lights in the finished room and the one light in the storage room. Only one set of wires at the light in the storage room. I would like if possible to have a separate switch control the storage room.
Michelle
Old 12-30-2011, 06:34 PM   #9
joed's Avatar
Do you want it completely separate form the other switch? If you do then you need to find a power source. You could run a new cable from the existing switch box to the new switch box or you could find a near by receptacle to get power from.
Old 12-30-2011, 09:53 PM   #10
Mlwhite's Avatar
Rewards Points: 29
Okay there is an outlet that I could tap into. When I tap I to the outlet do I run the power to the switch? Then run the switch to the light? What do I do with the wires already at the light?
Old 12-30-2011, 10:11 PM   #11
MarginallyQualified
forget about receptacles or getting power from them.
and forget about the existing switches.
focus on the UNSWITCHED power source and the light fixtures only.
Ideally... each fixture has unswitched power that you can then add switching to.
If the second fixture is "daisy chained" off the first fixture (as it shares the switch) then you need to get power to it. Ideally, you will be able to use the existing wire that comes to it from the other fixture to do that with.
(this will involve changing the tie ins at the fixture and existing switch)
Then run the new switch leg you need for the 2nd fixture.
hth
Old 12-31-2011, 09:41 AM   #12
joed's Avatar
Remove the cable from the first fixture that runs to the second fixture. If it is long enough then you can use it by running it to the new switch.
Add your cable from the receptacle to the new switch box.
Installing new switch from an old one. Indecisi0n Electrical 1 10-29-2011 11:33 AM
Tripped breaker installing new light switch? tylermac Electrical 3 02-05-2011 04:57 PM
In-Line Switch on Hard Wired Fixture 1sthome1068 Electrical 2 08-29-2010 07:42 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
