Installing New Sub Panel In The Attic - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-25-2013, 07:43 PM   #31
Master Electrician
Rewards Points: 3,746
Looking back at your photos, how do you expect to get 5 new circuits out of your existing load center?
brric is online now   Reply With Quote
Old 10-27-2013, 04:15 PM   #32
The five circuits will be replacing other existing K&T circuits. This is part of a rewire of the entire house.
Here are the pictures inside the main which were requested earlier:
https://db.tt/bs1dCGiJ
https://db.tt/G8yHMSQr
https://db.tt/0AWGcrRN
Ricyteach is offline   Reply With Quote
Old 10-27-2013, 04:22 PM   #33
Also, the lack of room in the existing main panel is another reason I was thinking about putting that sub panel in the attic. All I would have to do at first is install one new double pole breaker in the main. Would make the wife quite a bit happier if I wouldn't have to shut off the juice for as long that way.
I am slowly being convinced that the sub panel isn't needed, but it certainly would complicate things as far as keeping power available while I run the circuits. With a sub panel I could just get it all ready to go and then flip on the 60 amp breaker. Done.
Attic Ventillation Problem. Why Now? Hubs Roofing/Siding 2 03-19-2013 11:23 AM
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 03:45 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 03:09 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 06:27 PM
