Installing A New In-line Electrical Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 11:09 PM   #1
Installing a new in-line electrical outlet
hello, I am trying to install a new in-line electrical outlet. I need to tap into an existing line. The existing line is 14-3 wire and that is the type of wire I will be using. What is the correct diagram of this? Do I run a new line from the existing line to the outlet and then a new line from the outlet back to the other end of the existing? Do I need to break off the tab on the outlet? How do I attach the wires on the outlet, red, black, white... Thanks
Nedly83 is offline   Reply With Quote
Old 09-01-2009, 04:47 AM   #2
dSilanskas's Avatar
Well there are a few ways of doing this. First off the only reason they used a 14/3 is so that you can have one half of the outlet switched and the other half live all the time. Now if you just want to add another outlet and have the whole outlet live all the time and not controled by the switch all you need to do is run a 14/2 from the outlet your picking power from to the new one your adding. Make up the outlet that you added first so you don't have to worry about working it live. Bare copper wire goes to the greed screw, white wire goes to the silver screw and black goes to the copper screw. Now is the outlet you want to pull power from white goes to silver. splice the ground to the grounds and the black will get spliced with the black wire and add a jumper to the copper screw.
dSilanskas is offline   Reply With Quote
Old 09-01-2009, 05:58 AM   #3
Electrical Contractor
kbsparky's Avatar
I hope you are not tapping into an existing 3-way switch loop.
-KB
Old 09-01-2009, 07:03 AM   #4
Where is the existing outlet/circuit (room) ?
Where will the new outlet be located (room) ?
Some circuits can't leave the room where they originate - kitchen, bath - with some exceptions
Is the exisiting circuit a MWBC?
If not there isn't any reason to break off the tabs & use 14-3
Old 09-01-2009, 07:35 AM   #5
The existing circuit is in the attic and the new outlet will be in the attic. I wanted to tap into the existing line, not an outlet. Is that possible? If not, I may be able to tap into a light in the attic, but it is already in-line. I'm using 14-3 wire because that is the current existing wire. It is not a 3-way switch loop. I'm not exactly sure what MWBC is, but the wire I'm using is 14 gauge and has a red, a black, a white, and a ground wire.
Old 09-01-2009, 07:44 AM   #6
Is there an existing junction box that you are going to tap into?
You still need to verify what that circuit/wire feeds
It may be a wire for a 3 way switch for stairs/hallway light
MWBC - multi-wire branch circuit, where there are 2 circuits wired off the wire & breaker
Underground Electrical Line and water line. Randell Tarin Electrical 11 09-18-2011 08:19 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Help installing GFCI outlet kevind Electrical 8 03-02-2008 07:28 PM
Installing drain line parcially upgrade. jbravo8212 Plumbing 8 02-19-2008 05:12 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
