Old 06-14-2008, 01:32 AM   #1
Installing New Light Switch (NOT REPLACING AN EXSISTING ONE)
My laundry room had only a bulb with a plastic diffuser and a pull chain. I have installed a nice fixture, however, the fixture needs a switch. The box that the origianl bulb was wired from has only a black and white wire (rather old wire, I might add) and I purchased regulation wire (one white, one black and a ground).
The switch has the black screw, copper screw and ground screw. I am at a complete loss, as I have tried to wire the switch from the old box only connected to the new fixture with a line running to the switch. (light is always on and breaker blows when I turn light off).
The second configuration I tried, which I thought was correct; wire from exsisting box to the switch and then back to the new fixture. The only way I could see this working was to put both white, both black and both ground wires on each of their respective screws. This caused a similar issue with the circuit breaker.
I'm open and willing to take any suggestions to make this work, including but not limited to starting from scratch. I know there must be a simple solution … can anyone help?? I've obviously missed something here ...
Light Out on Hillsboro Be is offline   Reply With Quote
Old 06-14-2008, 07:47 AM   #2
If you have installed a new switch in the wall connect Black feed wire in light box to the black wire to the switch and the white wire to the other side of the switch to the light.The white wire in the light box hooks directly to the light. All you are doing is breaking the "hot" wire to the light. The ground wire is useless if there is no ground in the feeds to the light.
BillyD is offline   Reply With Quote
Old 06-14-2008, 10:47 AM   #3
Electrical Contractor
Not right!
Connect the black wire in the ceiling to the white wire(and mark this with a piece of black tape) that goes to the switch. From the other side of the switch, connect the black wire to the black wire on the light fixture, and connect the white wire in the ceiling to the white wire of the fixture.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 06-14-2008, 02:41 PM   #4
It is right. He did not ask about code he ask to hook up a switch and what I told him will work. If you want to train them to be an electrician then explain that the current carrying conductors need to be marked with colored tape (not just black) and that the romex has to be stapled, if it is a metal box it must be bonded, etc. Life is getting to complicated. Make it simple if possible.
Old 06-14-2008, 03:53 PM   #5
Licensed Electrician
J. V.'s Avatar
What color would you use for a switch leg?
Romex when fished through walls and ceilings not accessible require no support.
If it is a metal box feed with romex you ground the box and the device (EGC), not bond it.
Old 06-14-2008, 04:20 PM   #6
Black is your switched leg, but if you are adding a switch, it is going to be what Electricians call a "Suicide Switch". In other words, you will take the White leg on the Romex, and connect to one side of the Switch, then the Black to the other. At the Light, connect the Black leg from the Romex going to the Switch on the screw, then the White Leg, which has the Black Electricians tape on it so that the next "dummy" knows that it is Black, to the Black leg coming from the Romex going back to the Power Panel.
As for Asthetics, you can use Conduit, or Flat Electric channel to cover up the Romex from damage, along with a box that matches.
Old 06-15-2008, 09:54 AM   #7
jrclen's Avatar
It is very simple to do it correctly. Just as simple as doing it wrong. The problem with doing it the way you explained, is there would be two white wires connected to the light fixture and in the future someone may connect them incorrectly to make the screw shell hot. Doing the job the correct way, as jbfan laid out, gives you a black hot and a white neutral connected to the fixture. Also, inside the fixture box, a person in the future will clearly see a back wire connected to a white wire, a good indication that the white wire is being used as a hot wire whether it is taped or not.
John
jrclen is offline   Reply With Quote
Old 06-15-2008, 09:56 AM   #8
jrclen's Avatar
All the electricians I know call it a switch leg.
John
Tags
electrical, installing light switch, new wiring
More On This Topic
Michael Raines, Expert Village. So, let's get right into installing our X10 system. We're going to put in a wall switch. So, let's get to it. This is your everyday wall switch. Semi modern rocker switch, kind of nice but it's not remote control and it's... Read More »
Hi! My name is Adolph Ramirez from Tampa, Florida on behalf of Expert Village, this is how to install a ceiling fan. Make sure you disconnect all of your power; shut it off at the service panel. Don't rely on any kind of switches or anything like that... Read More »
Michael Raines with Expert Village. Okay, we've turned the power off. Let's take off our switch. Now, as I said, this one isn't connected to the terminals. It's connected through a push tube in the back, so you twist gently and pull then the wire comes... Read More »
Ok, now that we have all of our heating devices we need to talk about how to properly place them on the reptile enclosures to get your optimum heat. First and foremost, we have our day bulbs, and our night bulbs, ok. What we're going to need is we're... Read More »
Testing New Light Fixtures
Testing New Light Fixtures by Expert Village
Hi, this is Jon and in this clip, we will be testing our light. Now that our light has been properly wired and installed, we want to test it at this point to make sure that it works. The reason we test it now, rather than after we've put all of the glass... Read More »
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 08:32 PM
replacing light switch in bathroom cooper Electrical 3 02-22-2007 06:05 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
Installing a ceiling fan with a light switch. Unregistered Electrical 4 02-27-2006 07:15 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
