Installing A New Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 12-27-2008, 03:10 PM   #1
Rewards Points: 77
Angry
Installing a new light fixture
I have attempted to install a new light fixture in the hallway of my house (controlled by a switch) and have run into a problem. When the light fixture wiring is correctly hooked-up it shorts out and the breaker goes.
In the electrical box on the ceiling there is:
3 white wires
3 black wires &
1 red wire
When I connect the white to white, the black to black and connect the red wire to the WHITE wires the breaker will turn off when I flick the switch.
When I connect the white to white, the black to black and connect the red wire to the BLACK wires the light will stay on and the switch does not work at all.
Can someone PLEASE help me. This little problem is driving me MAD!
shorteared is offline   Reply With Quote
Old 12-27-2008, 03:17 PM   #2
General Contractor
The red wire should never be connected to the white wires.
If you have a multimeter you could use it to figure out which is the switch leg, however I suspect it is probably the red wire.
I would try connecting all the white wires together. All the black wires together(except the one on the fixture). Then connect the black wire from the fixture to the red wire.
jensenconstruction is offline   Reply With Quote
Old 12-27-2008, 03:28 PM   #3
Rewards Points: 77
Talking
THANK YOU so much. You have figured it out and resolved my crises here in Ontario.... Cheers. And thank you for the extremely quick reply
Tags
1 red , 3 black , 3 white , light fixtures , light switch
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 09:10 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
