Old 06-30-2012, 01:13 PM   #1
Installing a new condenser fan on my home a/c unit
The old motor has 3 wires the new one has 4 it has black, white, brown, and brown and white. Is the white a neutral and if so do I need to hook it up and just wire nut . I don't c a netural outside any where
Grinch is offline   Reply With Quote
Old 06-30-2012, 04:42 PM   #2
as seen on tv
condenser fan mtr's are typically 240v make sure you have the correct voltage, frame, hp, rpm. The black is hot and white would be hot and the other two would go to the run cap. Hots will be fed from load side of the contactor
qbert is offline   Reply With Quote
Framing and installing new patio door in older home MurphyMan Building & Construction 0 12-28-2011 07:56 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 03:41 PM
Installing unit myself stryped HVAC 8 08-05-2010 01:37 PM
Can I replace the condenser unit with a different brand? jimbovia HVAC 6 07-03-2010 12:56 PM
Help with outside condenser unit cablemn HVAC 5 06-14-2010 04:26 AM
