Installing New 220 Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 10:50 PM   #1
Installing new 220 breaker
For a 4 wire line for a dryer, how do I connect the neutral and ground wires into a breaker panel that has a common ground and neutral bus?
islan2der is offline   Reply With Quote
Old 10-19-2012, 11:22 PM   #2
" Euro " electrician
frenchelectrican's Avatar
If this panel is a real main breaker panel then the netural and ground is there on the common netural / ground bussbar but just make sure you only use one hole per netural but the ground can be bundled up.
That part I rather run it own due the conductor size.
But if your panel do have seperated ground bussbar then seperate them and hook them up in proper place et it is not very hard to find them in the panel.
The neutal bussbar will have a bit of white conductors go on that bussbar ( sure there will be bare or green but once you have subpanel then the bet is out of the window. )
Merci,
Marc
GFCI Breaker Tripping Spa Light eaposition Electrical 21 09-08-2010 09:57 PM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 08:20 PM
Installing a breaker "backwards" jcliffo Electrical 4 11-16-2009 10:38 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
