Installing Load Center - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2010, 12:19 PM   #1
installing load center
I have a work shop that is fed with two 12/2 w/ground wires that travel over 100 feet from the main circuir box. I would like to install a circuit box in the shop so I don't have to go down in the cellar incase a breaker trips. Can this be done with the existing wires or do I have to run a new service wire?
Jim Wats is offline   Reply With Quote
Old 08-27-2010, 12:31 PM   #2
Licensed electrician
Rewards Points: 1,018
The first problem would be that if the workshop is detached it can only de fed with a single circuit. The other problem is that feeders need to be 4 wires. You could only supply a panel with 120 volts given your setup.
I would advise you to install a 50-60 amp subpanel in the shop. To do this you would ned to install a 4 wire feeder.
Jim Wats (08-31-2010)
Old 08-30-2010, 08:55 AM   #3
Load Center
In my last post I stated that I have two 12/2 with ground wires running to my shop. These wires are on two separate 20 amp circuits. The shop is detached from the main house and the wires are running through conduit under ground. When you say that the feeder needs to be 4 wire can this be done with these existing wires? I want to put in a 60 amp load center. I will not be using anything that requires 220 volts.
Old 08-30-2010, 09:13 AM   #4
For a 60 amp feeder you would need #6 copper. The #12 is limited to 20 amps.
Depending on the size of the conduit you may need a larger conduit or need to downsize the feeder size to the workshop and install smaller wires.
Old 08-30-2010, 10:00 AM   #5
Detached structure you can have:
One single circuit
Multi-wire branch circuit (MWBC) - 2 circuits that share a neytral
OR
4 wires feeding a sub-panel, 2 ground rods required
60a is a standard size
4 wires are required which can give you 240v if needed
Or you will have 60a 120v on each bus
I used a 100a sub & fed it from a 60a breaker in the main panel
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 08-30-2010, 11:44 AM   #6
Rewards Points: 58
Lets be perfectly clear on this. The existing installation is a violation of the NEC. Art. 225.30
So if you want a panel follow Jim Ports advice.
The Following User Says Thank You to J. V. For This Useful Post:
Old 08-30-2010, 12:57 PM   #7
No, you can't use the existing wires to feed a 60a panel
Old 08-30-2010, 11:29 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Unforetally the guys allready give ya the correct answer to this and if you really want a subpanel you have no choice but run 4 conductor to the subpanel and of course you will have to sink two ground rods.
AND make sure you keep the netural and grounding conductor seperated this is very important part.
And yeah ditch the bonding strap or screw if they come with it.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 08-31-2010, 11:29 AM   #9
Rewards Points: 58
Merci.
Marc
And make sure the 2 - 20 amp circuits running out there are abandoned/removed.
Jim Wats (09-01-2010)
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 12:28 PM
Jacking up house, full length joists raised beam off of center colums. Suggestions? slowjo Building & Construction 9 09-16-2014 07:56 AM
installing recessed lights, entertainment center overload? fabian Electrical 5 01-13-2010 01:25 PM
Installing a Hottub/Jaccuzi help? Morndenkainen Electrical 7 11-08-2009 09:33 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
