Installing A Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 08:41 PM   #1
Installing a light switch
In my finished basement, one switch controls all of the lights. There is the general basement area, and then there is a bedroom. I'd like to install a switch in the bedroom to control those lights separately, but I don't know how I would do that. Any ideas?
JoeyJoeJo is offline   Reply With Quote
Old 01-08-2011, 02:41 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
Where are you located. How much access do we have to the wiring? How familiar are you with circuitry? Romex? Then all we need to do is install a old work box and fish some wire.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-08-2011, 01:40 PM   #3
I'm located in Virginia. As for access to wiring, everything is behind drywall, ceiling included. I'm only slightly familiar with circuitry. I've replaced outlets and switches before, but never wired something new like this. I've heard the word Romex, but I'm not really sure what it is. I do have some 14/2 wire for the job though.
Old 01-08-2011, 01:58 PM   #4
Scared Electrician
If this is a 15a circuit then14-2 is ok. for got to ask what kind of lights, can we access the wiring boxes by taking down the bulbs? If they are can lights this can be done but is more difficult.
Now power will run from light to light to light to bedroom light to bedroom light. what we need to do is figure out which light in the bed room is the first in line. From this first light we will need to run a switch leg, after making the switch hot and disconnect it from the main room lighting.
So a ideal situation would be if the light was in between to joists(we can remove the light box to see inside drywall) and when those two joists run in to the wall we could cut in a switch, and on that wall would be a plug we could get power from.
If this can be done we'll help you with methods.
Old 01-08-2011, 02:15 PM   #5
These are not can lights. As for what light is first in line, here's the deal. The circuit panel is in this room. I think it goes from the circuit panel to the first light in the room. Will that create any problems?
Old 01-08-2011, 02:30 PM   #6
Scared Electrician
So the panel is in the bedroom. This might require drywall patching. some photos perhaps?
Old 01-08-2011, 02:35 PM   #7
liscenced electrician
Rewards Points: 538
a picture is worth a thousand words. Take a couple pictures and maybe draw a diagram of how you think the wires are ran
jimmy21 is offline   Reply With Quote
Installing a ceiling fan with a light switch. Unregistered Electrical 9 08-23-2011 03:36 AM
Remove Switch from controlling outlet/wire wall light to wall switch salesbyashley Electrical 2 08-26-2010 02:07 PM
installing a motion sensor light on a two way switch dwittekind Electrical 3 08-11-2010 08:19 AM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
