Installing Light On Round Junction Service Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 05:33 PM   #1
Installing Light on Round Junction Service Box
I am trying to replace an outdoor light. The current light has a round mount and mounts over the round service junction box on the outside of the house. (The junction boxes are not recessed.) The new lights have a rectangular mount. When I mount them over the junction box, they stick out from the wall (not surpising) and don't sit squarely. (See attached picture.) I'm also concerned about water getting into the wires so easily since the rectangular mount doesn't fit over the round junction box in any fitted way. Is there some sort of plate that would help me use the round service junction box to mount these lights?
MegR is offline   Reply With Quote
Old 01-08-2012, 06:14 PM   #2
MarginallyQualified
Rewards Points: 2,464
why? it's cool.
Oh, yeah... that one. I like it!
... the electrical box isn't/shouldn't be a problem.
Not likely. What you're gonna need to do is mock up something on your own (or have it fabbed) to install around that box (and conduit) for the fixture to mount flush to.
It doesn't have to be complicated or fancy...
most sheet metal shops could make a "box" that could be painted.
hth
Old 01-08-2012, 06:20 PM   #3
Rewards Points: 13,300
That's one ugly way to run wiring and a box.
Just change the juntion box.
Unless that whole set up is redone there is no way to get the light to sit flush.
Concider redoing at whole wall with foam insulation and adding siding over it.
Old 01-08-2012, 07:32 PM   #4
Licensed electrician
Rewards Points: 1,266
This is what you really need, however I don't know of a way to get a surface mounted cable to work with one.
http://www.aifittings.com/catalog/si...unting-blocks/
Old 01-08-2012, 08:18 PM   #5
Master Electrician
Rewards Points: 3,760
Geez, Jim. Just run the cable into the side of the box like it is right now.
brric is offline   Reply With Quote
Old 01-08-2012, 08:23 PM   #6
In the end it wouldn't be any worse than it already is. Just a little too hack for me.
Old 01-08-2012, 09:13 PM   #7
Tarheel is right, change the light or get a carpenter to make you something.
Jdizzle is offline   Reply With Quote
Old 07-07-2013, 09:31 PM   #8
MegR, I am having the exact same problem with a new porch light/ round junction box. What did you do to fix yours?
ValAK is offline   Reply With Quote
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-05-2011 12:17 AM
fluorescent light as junction box jimaro Electrical 1 11-13-2011 07:09 PM
Advice on installing island light junction box MBD DIYer Building & Construction 3 04-04-2010 10:06 PM
Installing a Bahroom Fan with Light wiring Help bemgolf Electrical 5 12-24-2009 02:46 PM
Installing New Porch Light, Electrical Box GeauxCajuns82 Electrical 1 12-19-2008 06:16 PM
