-   -   Installing Light Fixtures in Bath (http://www.diychatroom.com/f18/installing-light-fixtures-bath-52117/)
mrsjande 09-01-2009 10:08 AM
There is not a mouting bracket to install my new light fixtures! Help me update my old home with some new lighting!
1. Canister lighting in bathroom is just a single light attached to wiring via a L-joint screwed into the drywall. Are there issues putting in pendant lighting? I just want to hang a single pendant but there's no mount for it. Do I need to remove the canister and somehow attach a mount?
Also, the pendant is much smaller than the canister. I think I need to make some repairs to the ceiling for sizing. Maybe I should have waited to paint!
2. Track lighting above vanity. It's just screwed into the wall with wires running to each bulb. Can I install new track lighting? How should it be safely mounted into the wall?
http://img232.imageshack.us/gal.php?g=trouble002.jpg
J. V. 09-01-2009 01:53 PM
How wide is the can light? When you buy a fixture you get the hardware required for the fixture. Since you have can light you have no ceiling box. You need a ceiling box. Like the picture below. Pick a light fixture with a canopy that will cover the box, and any remaining visible hole.
mrsjande 09-01-2009 07:04 PM
The canister is significantly larger than the pendant, which I got from Home Depot. I will look for the correct ceiling box and get a larger canopy to make my life easier. No drywall repairs sounds good!
Where can I find a good selection of hardware? Home Depot is very sad.
jbfan 09-02-2009 08:55 AM
If you have the can light over the tub or shower, you can not hang a pendent light in its place!
mrsjande 09-02-2009 12:15 PM
I can do whatever I want!! But no, it's not over the bathtub. That would be silly. :laughing:
My hubby thinks we should just leave the canister alone. It is, after all, just a water closet.
300zx 09-02-2009 12:38 PM
You could also KILL YOURSELF OR SOMEONE DOING THINGS WRONG. http://sound.westhost.com/articles/electrocution.htm
Termite 09-02-2009 02:27 PM
Unfortunately your hubby is dead wrong. The can light needs to be entirely removed prior to installation of this light. Covering the can is absolutely illegal and is unsafe. Pretty hard to do this without drywall patching, especially since the can light housing is much larger than the ceiling box. The installation of a proper ceiling box in the drywall is necessary to safely mount the new fixture and to contain the connections.
mrsjande 09-03-2009 03:15 PM
He thinks I should not ADD a light and we should just have the canister lighting in that room period. Nothing dangerous/not up to code/stupid. :laughing:
mrsjande 09-03-2009 03:19 PM
I thought that was why you turned off the breaker when playing with wires? (I'm not out to win any Darwin award.)
This really is too much trouble! I think I'll just keep the ugly canister and work on the track lighting for the vanity instead (Sheesh, boys!)
