-   -   installing light fixture in old box (http://www.diychatroom.com/f18/installing-light-fixture-old-box-116115/)
annie68164 09-03-2011 05:57 PM
So I just got done installing a new,simple light fixture into the ceiling. I go to turn it on, nothing happens, change the bulb, still nothing. The box is old, round, shallow with confusing wires. On one side you get white and black, on the other side is white. All are copper from what I can tell. They are thick and stiff but I was able to secure them to the new wires from the new fixture using those plastic screw on deals. I will say a bit of copper overhang was exposed outside of the screw on deals.I attached black to black, white to white, then the green ground I attached to the white on the other side of the box. I assumed this was the ground. I did not use the included brace because it was too crowded with all those thick damn wires in this tiny shallow circle, and I didn't see any use for it except as a brace which I didn't need, the mounting screws alone were just fine. Is that what messed it up? I'm an amateur (obviously) but I had installed a fixture in this same spot a few years ago with no problem. I know you are thinking I better quit before I set the damn house on fire....
CheapCharlie 09-03-2011 06:23 PM
You'll have to describe what wires are in the box a little better. A picture would be best. to have 1 black and 2 whites doesn't make sense.
kbsparky 09-03-2011 06:25 PM
There were only 3 conductors entering that box? Do you have knob-and-tube type wiring?
I'd be willing to bet that your wiring is not grounded, and that lone white wire needs to be connected elsewhere for it to work ....
annie68164 09-03-2011 07:22 PM
I will try to post a pic. Basically it's like white and black wires on left side of box, white wire alone on right side. All are identical thickness. Also a new discovery is that the ceiling light won't come on the adjoining bedroom now. checked the circuit breakers and nothing is tripped so I must have fried something????
Jim Port 09-03-2011 09:51 PM
I am going to state that a new fixture probably should not be installed there. Most ceiling mounted fixtures have a warning to only use with 90 degree rated conductors. Your old conductors are not even close to 90 degree rated.
kbsparky 09-03-2011 10:08 PM
Connect both white wires together, and restore power. Betcha the light in the other room starts working again.....
