Installing Light Fixture With No Ground From Source - Help! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 01:22 AM   #1
installing light fixture with no ground from source - help!
An electrician disconnected the old pendant light and as I went to replace it today realized that there isn't a ground wire from the blue junction box. Can I just connect the ground wire from the fixture to the green screw on the mounting plate and be ok? Also, the previous fixture had a transformer which I can't even begin (although have tried looking it up) how that was all connected....esp. without a ground wire from source. ALSO, since both of the source wires are so well taped up I can't figure out which is white or black....guessing I need to untape and retape once I have it figure out, right?
thanks!
lswenn is offline   Reply With Quote
Old 03-29-2011, 07:52 AM   #2
Rewards Points: 1,440
THe light fixture will work perfectly fine without a ground (The old light fixture worked fine without a ground).
It is not mandatory to rewire that circuit let alone your entire house to install that light fixture.
To find out which wire is the hot wire (and should not be white), do this before installing the light fixture: Turn the power on, flip the switch on, and measure voltage between one loose end and the metal box (or between one loose end and a long wire you have strung from a known ground such as a radiator, across the floor, to where you are working. Repeat for the other wire end up in the ceiling. The one that reads 120 volts is the hot wire and the other is the neutral.
See if there is a bare wire accompanying the two taped wires into the box. If so, this is your ground wire. Connect it to the metal box and also to the ground wire or ground screw of your new fixture using extra short lengths (pigtails) of bare wire and a wire nut if needed.
You can optionally string a permanent ground wire from that fixture to the panel where the breaker for that circuit is located. The wire does not have to follow the exact route of the wires and cables of that circuit back to the panel.
Tags
light installation , no ground
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 07:49 PM
LIcensing requirements for installing a Light Fixture. FunkyMonkey Electrical 6 12-04-2010 09:29 AM
help with installing light with no ground jayp Electrical 2 02-05-2010 11:07 AM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 09:10 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
