Installing Light Fixture With No Electrical Box - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2011, 09:11 PM   #1
Installing light fixture with no electrical box
I would like to install a chandelier in a room with no overhead light fixture and therefore no electrical box. I do not need electricity, I am planning to use flameless candles. The fixture is about 10-15 lbs. I would like to mount it to the ceiling without cutting a hole in the drywall and installing a box--I am not that handy. Is this possible?
tiffmorrison is offline   Reply With Quote
Old 11-07-2011, 10:55 PM   #2
Probably with a large enough toggle bolt to spread the weight.
hayewe farm is offline   Reply With Quote
Old 11-08-2011, 10:02 AM   #3
Rewards Points: 3,130
Do you have access to the other side of the ceiling from above? If so, install a section of blocking between the rafters so you'll have something solid to screw into.
HELP! Major problems installing a new light fixture katemeyer Electrical 9 10-24-2011 06:30 AM
Help installing light fixture GaugedUp Electrical 3 08-29-2011 09:45 PM
Installing a new light fixture shorteared Electrical 2 12-27-2008 03:28 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
