Installing A Light Fixture To A Joist - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 10:44 PM   #1
Rewards Points: 12
Question
Installing a Light Fixture to a Joist
I'd like to install a light fixture in the stairwell leading to my basement. The current fixture is at the bottom of the stairwell and doesn't light the stairwell very well. At the bottom of the stairwell is a joist that was drywalled over and I'd like to install the new fixture directly to this "wall" (joist). The problem is that there's no place to install a junction box without putting a huge hole in my floor joist. I'm basically mounting directly to the vertical side of a drywalled joist.
Are there light fixtures that can be directly mounted to the joist while containing the connections without a junction box? In this case the wire would go through the joist and into the fixture directly. Or, can/should I use a pancake box to contain the connections? Or, is neither of these the proper way to do this? Thanks in advance for any help!
BOOTHA06 is offline   Reply With Quote
Old 06-30-2012, 10:50 PM   #2
Rewards Points: 13,724
Not sure what your talking about, how are you going to mount the light to the side of the joist if there's already sheetrock on the ceiling?
Think about one of these instead.
http://www.pegasuslighting.com/5inch...n=pricegrabber
BOOTHA06 (06-30-2012)
Old 06-30-2012, 10:56 PM   #3
Rewards Points: 12
I'll try to explain more clearly. This will not be on a ceiling, but on the side of a floor joist that faces into the stairwell at the bottom of the stairwell. They drywalled the 10 inch side of the joist to give it a finished look that matches the rest of the "inside of the stairwell. More simply, how do you install a light fixture to the 10" side of a 2x10 without drilling a 3-4 inch hole in it for a junction box?
Old 06-30-2012, 10:59 PM   #4
Post a picture and make it simple for everyone.
Old 06-30-2012, 11:01 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Drill the wire thru the joist and install a flourescent undercabinet style fixture.
Or you can cut in a pan box (a round 1/2" deep box) into the drywall and you can install a sconce type fixture.
The Following User Says Thank You to k_buz For This Useful Post:
Old 06-30-2012, 11:16 PM   #6
Rewards Points: 12
Pictue of this scenario
This pic is looking up from the floor. I'd like to go from the current light, through the joist with the blue cat-5 on it, and mount directly to the other side of that (double) joist. It doesn't seem like it would make that much difference, but the new light will be directed into the stairwell, rather than into the basement.
Old 06-30-2012, 11:29 PM   #7
k_buz's Avatar
That appears to be an engineered joist and (probably) not able to be drilled thru.
Old 06-30-2012, 11:30 PM   #8
Rewards Points: 12
This seems like a good idea. At some point soon I'm gonna have inspectors poking around. Will this meet NEC code?
Old 06-30-2012, 11:32 PM   #9
DIY staff
Rewards Points: 7,174
I did not read all of the thread---
There is a 1/2" deep round steel electrical box designed for just your situation---cut a round hole in the drywall--pull your wires--attach to the 'pancake box---screw to the joist--all done---they make handy job site ashtrays also---
Old 06-30-2012, 11:34 PM   #10
Rewards Points: 12
It's regular lumber and the original builder went through them at several other points along the joists. I have a couple engineered joists, but this isn't one of them.
Old 06-30-2012, 11:34 PM   #11
DIY staff
Never mind---Someone has your situation in hand--I'm going to bed--Mike---
Old 06-30-2012, 11:48 PM   #12
Rewards Points: 12
I don't smoke, but if I ever take it up I'll remember this advice... can I have a 14-2 coming in and a 14-2 going out of this box? I'd like to install a couple other fixtures downstream. That's not too many wires for this box, is it?
Old 06-30-2012, 11:51 PM   #13
DIY staff
Let K buz answer that--I'm not a licensed electrician and his knowledge of codes and box fill exceeds mine---
Old 07-01-2012, 12:41 AM   #14
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
That will be too many wires for a pancake box.
A round smart box will work.
Cut the hole in the drywall, run your wires and the box mounts with screws from the inside.
Old 07-01-2012, 07:33 AM   #15
Rewards Points: 12
I checked out their website. Isn't this going to stick out past the drywall just like a standard work box would or is there something about it that I'm missing? If it has to stick out a little bit to be safe, I'll deal with it, but I'd rather it not.
Tags
electical wiring , joist , junction box
Electrical Short in New Light Fixture amateur1 Electrical 14 04-10-2012 07:45 PM
Installing light fixture with no electrical box tiffmorrison Electrical 2 11-08-2011 09:02 AM
Installing a pull chain ceiling fixture safron Electrical 16 08-22-2011 05:13 PM
Installing a new light fixture shorteared Electrical 2 12-27-2008 02:28 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
