Installing Kitchen Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 08:43 AM   #1
installing kitchen recessed lights
I'm not sure how to wire my kitchen lights. I'm going to install five 5" recessed lights in my kitchen. Do I wire them in series , or should I run all the wires into a box and wire them in parallel? I'm going to use CFL bulbs in them if that makes any difference.
UFoPilot is offline   Reply With Quote
Old 03-25-2012, 08:45 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Run the wire from one light to the other..."daisy chain".
The Following User Says Thank You to k_buz For This Useful Post:
UFoPilot (03-25-2012)
Old 03-25-2012, 10:37 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Either way they are wire in parallel. Physically they might look like series, so I get what you mean.
Wiring to a j-box and out to the lights from there typically seems like a good idea to a DIY, but this is a very poor way of wiring. It adds failure points and creates splices with a large number of conductors, also a problem for most DIYers.
Just wire from light to light. Are you experienced enough to know how this works?
Speedy Petey is online now   Reply With Quote
Old 03-25-2012, 10:53 AM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Most cans these days are designed with quick connects in them to make it very easy for you to "daisy chain" the wire from 1 light to the next.
sublime2 is offline   Reply With Quote
Old 03-25-2012, 01:48 PM   #5
Thanks, That is what I'll do.
Old 03-27-2012, 02:07 AM   #6
Rewards Points: 956
can you elaborate briefly? i am doing the same thing but its using LED disc lights. 4 of them total in the ceiling.
federer is offline   Reply With Quote
Old 03-27-2012, 06:12 PM   #7
Licensed electrician
Rewards Points: 1,622
Are you really asking how to run a cable between two points?
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
federer (03-27-2012), MisterZ (03-27-2012), Speedy Petey (03-28-2012)
Old 03-27-2012, 10:31 PM   #8
"So I Re-Wired It"
MisterZ's Avatar
LMAO:D
just connect the lights in-line with each other.
1st to the 2nd to the 3rd, etc
MisterZ is offline   Reply With Quote
Old 03-27-2012, 11:10 PM   #9
Rewards Points: 956
yea i suppose. the guy was nice enough to ask so i thought i follow up to make sure. i am not much of a electrical guy as you guys see
Installing remodel recessed lights in manufactured home. MikeVila Electrical 14 08-03-2011 07:06 AM
Need advice for 50-watt recessed lighting in the kitchen mystiky Electrical 3 04-26-2011 10:16 PM
installing recessed lights, entertainment center overload? fabian Electrical 5 01-13-2010 12:25 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
Installing motion / security lights west-phoenix-az Electrical 2 07-11-2008 07:33 PM
