#1 |
installing ikea ceiling lamp
i am trying to install an ikea ceiling lamp which has a black wire a white wire and a green/yellow wire, in the ceiling here is a white a red and black and brown wire. which wires connect to which
#2 |
" Euro " electrician
Are you in Chicago area ?
If so then brown is your switched connection but before you do that double check to make sure. And I am seriously advise you make sure you turn off the breaker on this circuit due you may have MWBC { MultiWire Branch Circuit } there. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
#3 |
allo Marc, i live in toronto, merci de m'avoir repondu, here is my problem.
i tried connceting the wires and kept blowing the fuse each time i try turning the switch to the off position. any advise you may have helping me with this would be greatly apprecieated. Merci beaucoup. |
#4 |
Bonsoir Handyman39.,
Do you have a test light with you if so read between the black et white and red et white also white et brown but I doubut it due that brown may be a faded white from older conductor { wire } and look at your switch to take a quick peek how it hook up and post us the colour. Merci, Marc
| Display Modes | |
| Installing a ceiling fan in a new construction home | HEMMY1244 | Electrical | 4 | 09-15-2010 08:11 AM |
| NEW PLEASE HELP!question IKEA's ceiling lamp | vivian8 | Electrical | 10 | 01-06-2010 07:46 PM |
| Converting a ceiling lamp holder to a grounded outlet | koz | Electrical | 2 | 12-30-2009 07:24 AM |
| Installing a ceiling light fixture? | DK75 | Electrical | 7 | 02-27-2006 09:10 AM |
| Installing a ceiling fixture | Cregan | Electrical | 3 | 02-08-2004 10:43 PM |
