Installing A Honeywell RTH2300B Thermostat To A Gas Furnace. Have The Standard WYRG Wiring. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-25-2011, 12:19 PM   #1
Installing a Honeywell RTH2300B thermostat to a gas furnace. Have the standard WYRG wiring.
Do I remove the cover on the JP1 or leave it on?
Devan813 is offline   Reply With Quote
Old 12-25-2011, 01:04 PM   #2
Rewards Points: 6,652
Really need to post a picture. Are you asking to pull the jumper on the furnace board? You need to post model & manufacturer of the furnace & a/c or heat pump also. What is the wiring that is on the thermostat that is installed currently? To give you an idea, you just need to hook up the same as it is now, to the new thermostat, and then follow the instructions to set up the new thermostat.
If you do not have the owner's manual for it, here it is http://www.honeywellcentral.com/prod...mostat-rth230b
Old 12-25-2011, 04:04 PM   #3
Replacing Thermostat
Hello Greg,
I connected the wiring per instructions. My question is dealing with the small black plastic covering on the JP1 (lower left side of thermostat). When I initially installed the unit cold air came out of the vent indicating something was wrong. After re-reading the instructions it is unclear on the setting of the jumper JP1. If a green wire is connected to the terminal set the jumper. Then it says HG leave the jumper in this factory-set position if you have a gas or oil furnace (which I do). What is HG and which way do I go?
Old 12-25-2011, 05:19 PM   #4
J2 sets it for either electric or gas system. What is the model & manufacturer of the furnace and a/c.
It states in the instructions in the link I posted.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Help Wiring Programmable Thermostat Brio9 HVAC 4 02-13-2011 11:25 PM
The Right Thermostat? (Honeywell says two diffrerent things) FourIsWaltz HVAC 3 10-10-2010 08:20 PM
Programmable Thermostat to Furnace Wiring JeremyB HVAC 1 07-14-2010 06:05 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
