Old 01-16-2011, 04:28 PM   #1
Question
Installing HAF FANS
Hi there i am installing 4- haf fans in my greenhouse and they are going to run in series. The total length of wire from the wire to the last haf fan is going to be 185 feet. This is the ratings for the haf fan: 120V/60hz and .78 amps.
I have a carol 3/c 18 AWG water resistant 300volt wire. Could i use that wire to run all the haf fans at the same time? Also what size breaker should i use?
THANKS
markadams is offline   Reply With Quote
Old 01-16-2011, 06:09 PM   #2
Electrical Contractor
Installing HAF FANS
No! You must use an aprroved wiring method for your area.
Carol cable is an extension cord.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-17-2011, 04:09 PM   #3
Installing HAF FANS
Do you know what gauge the wire should be ??
Installing electrical boxes for ceiling fans Evil Scotsman Electrical 12 11-17-2010 05:18 AM
Best way to test wiring prior to installing ceiling fans Troglodyte Electrical 9 05-24-2010 07:26 PM
2 Bathroom fans to 1 roof vent? theatretch85 Kitchen & Bath Remodeling 12 07-28-2009 03:25 PM
Roof fans sucking air through chimney? Badfish740 HVAC 8 10-08-2008 11:01 AM
Attic venting - Ridge vents or fans? jebmke Roofing 16 07-03-2008 12:03 PM
